| Plug-ins work in runtime, but don't after deploying [message #300733] |
Thu, 16 March 2006 09:24 |
Originally posted by: kolosovskaya_t.yahoo.com
I have a problem:
I created two plugins, one of them declares extension point and the second
one extends this extension point (through implementing required
interface). When I choose Run as... Eclipse application for plugin project
(for ANY plugin project, not necessary for mine!!!), my two plugins work
fine. But when I start eclipse and try my plugins in development mode
(before that I deployed them and put jars in /plugins folder of
eclipse),the extending plugin doesn't work: CoreException (plugin XXX was
unable to load class xxx, where XXX is extending plugin) in
createExecutableExtension(...) method because my extending plugin doesn't
see interface required for extending (java.lang.NoClassDefFoundError). I
call createExecutableExtension by myself while lazy-processing all
extensions of my extension point.
This is the Manifest.mf file of plugin with extension point:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Hadrian2 Plug-in
Bundle-SymbolicName: Hadrian2; singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: hadrian2.Hadrian2Plugin
Bundle-Localization: plugin
Require-Bundle: org.eclipse.gef,
org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.core.resources,
org.eclipse.ui.ide,
org.eclipse.ui.views,
org.eclipse.ui.workbench,
org.eclipse.jface
Eclipse-AutoStart: true
Export-Package:
hadrian2.extpoints.composers
Bundle-ClassPath: .
hadrian2.extpoints.composers is the package where all the classes for the
extension point are defined.
This is the Manifest.mf file of extending plugin:
Bundle-Name: ConfigVariablesComposer Plug-in
Bundle-SymbolicName: ConfigVariablesComposer; singleton:=true
Bundle-Activator: configVariablesComposer.ConfigVariablesComposerPlugin
Require-Bundle: org.eclipse.ui,
Hadrian2
Bundle-ClassPath: .
As you can see, I export the required package from plugin with extension
point and point to plugin with extension point in extending plugin. It
seems to me, I've tried everything but still have the problem.
Can somebody help me please?
FUDForum. Page generated in 0.02917 seconds
