Home » Eclipse Projects » Eclipse Platform » Unhandled event loop exception
Unhandled event loop exception [message #300720] Thu, 16 March 2006 07:00 Go to next message
Originally posted by: pksr.wanadoo.nl
Hello all,
I get an internal error when i click on the hint in the margin of a line
of java code. The hint pops up and then i get the internal error message
stating that an SWT error has occured. In the .log file I see the
following lines:
eclipse.buildId=M20050929-0840
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_NL
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2006-03-16 12:02:01.796
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-03-16 12:02:01.796
!MESSAGE No more handles
!STACK 0
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:2968)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:48 2)
at org.eclipse.swt.widgets.Composite.createHandle(Composite.jav a:229)
at org.eclipse.swt.widgets.Decorations.createHandle(Decorations .java:413)
at org.eclipse.swt.widgets.Shell.createHandle(Shell.java:448)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:49 7)
at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.j ava:131)
at org.eclipse.swt.widgets.Decorations.createWidget(Decorations .java:421)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:255)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:332)
org.eclipse.jface.text.DefaultInformationControl.<init>(DefaultInformationControl.java:130)
org.eclipse.jface.text.DefaultInformationControl.<init>(DefaultInformationControl.java:110)
org.eclipse.jface.text.DefaultInformationControl.<init>(DefaultInformationControl.java:211)
org.eclipse.jface.text.DefaultInformationControl.<init>(DefaultInformationControl.java:250)
org.eclipse.jdt.internal.ui.text.correction.JavaCorrectionAs sistant$1.createInformationControl(JavaCorrectionAssistant.j ava:98)
org.eclipse.jface.text.AbstractInformationControlManager.get InformationControl(AbstractInformationControlManager.java:61 9)
org.eclipse.jface.text.AbstractInformationControlManager.int ernalShowInformationControl(AbstractInformationControlManage r.java:850)
org.eclipse.jface.text.AbstractInformationControlManager.pre sentInformation(AbstractInformationControlManager.java:836)
org.eclipse.jface.text.AbstractInformationControlManager.set Information(AbstractInformationControlManager.java:291)
org.eclipse.jface.text.contentassist.AdditionalInfoControlle r.computeInformation(AdditionalInfoController.java:236)
org.eclipse.jface.text.AbstractInformationControlManager.doS howInformation(AbstractInformationControlManager.java:820)
org.eclipse.jface.text.AbstractInformationControlManager.sho wInformation(AbstractInformationControlManager.java:810)
org.eclipse.jface.text.contentassist.AdditionalInfoControlle r$1.run(AdditionalInfoController.java:173)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
what is the poroblem? I'm workin with Eclipse 3.1.2 and Java SDK 1.5.0_06
on a Windows XP machine.
Re: Unhandled event loop exception [message #300723 is a reply to message #300720] Thu, 16 March 2006 07:12 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
You are running out of handles for your widgets
Seems like you have a seriouse handle leak in your app. Remember to
dispose any widget you created you no longer need.
Stefan
Peter wrote:
> Hello all,
> following lines:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 1.5.0_06 on a Windows XP machine.
Re: Unhandled event loop exception [message #300728 is a reply to message #300723] Thu, 16 March 2006 07:54 Go to previous messageGo to next message
I dont think that is the problem because I also get it when I start
Eclipse in a new workspace with just one class that contains an error.
When I click on the error in the margin the SWT internal error occurs.
Regs,
Peter
Re: Unhandled event loop exception [message #300893 is a reply to message #300728] Sun, 19 March 2006 08:44 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
It's an OS thing. If you've run out of handles, and you start up a new app, that won't be able to create it either. If you see this same behaviour after a reboot, then yes, it's a problem with your code. If a reboot cleans it up, it probably just means there was a memory/SWT-handle leak that you're falling over with.
Win9x had a more serious problem with OS-handles than more recent versions of XP, so it would also be useful to know which OS you're experiencing this from.
Alex.
Re: Unhandled event loop exception [message #301334 is a reply to message #300893] Tue, 28 March 2006 16:54 Go to previous message
Originally posted by: poumy.freesurf.fr
Hello
I have the same issue on mon Suse 10 Linux (I use eclipse 3.1) :
as soon as I click on "Finish" during the first BIRT tutorial report, elcipse crash after a message about a SWT Error :
here is the log:
Reason:
No more handles [Unknown Mozilla path (MOZILLA_FIVE_HOME not set)]
Please advice I would really like to see BIRT work ! ;-)
Raphael POUMAREDE
Previous Topic:Where are "derived resources" marked as such?
Next Topic:How to protect a plug-in
Current Time: Sun Nov 23 05:32:19 EST 2025
Powered by FUDForum. Page generated in 0.04353 seconds
