Home » Eclipse Projects » Eclipse Platform » How can I reconstruct an SWT interface dinammically?
How can I reconstruct an SWT interface dinammically? [message #300179] Fri, 03 March 2006 09:25 Go to next message
Originally posted by: alexandregazola.yahoo.com.br
I have an SWT interface (a Dialog, for instance). This dialog has some
check buttons, labels, texts and a button called "Refresh". When the user
clicks on the button, I want to reconstruct this interface (the same
interface) with different elements (other check buttons, other labels,
other texts and the "Refresh" button) dinammically. How can I do this?
regards,
Alexandre
Re: How can I reconstruct an SWT interface dinammically? [message #300181 is a reply to message #300179] Fri, 03 March 2006 10:02 Go to previous messageGo to next message
see
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet98. java
"Alexandre Gazola" <alexandregazola@yahoo.com.br> wrote in message
news:c7be135c290f7e48d4321586188da40c$1@www.eclipse.org...
> regards,
> Alexandre
Re: How can I reconstruct an SWT interface dinammically? [message #300199 is a reply to message #300181] Fri, 03 March 2006 13:58 Go to previous messageGo to next message
Is there how to reconstruct just one composite?
For example, I have a composite called composite2 inside a composite1 that
is inside the shell. My composite2 has some widgets in it (including the
button). But, when I use the code bellow, after clicling on the button, by
composite (with all its widgets) disappear from my interface (instead of
appearing with my new components).
composite2.dispose();
composite2 = new Composite(composite1, SWT.NONE);
// create all widgets here
can anybody help?
thanks
Re: How can I reconstruct an SWT interface dinammically? [message #300201 is a reply to message #300199] Fri, 03 March 2006 14:58 Go to previous message
> that is inside the shell. My composite2 has some widgets in it
> (including the button). But, when I use the code bellow, after
> clicling on the button, by composite (with all its widgets) disappear
> from my interface (instead of appearing with my new components).
composite1.layout(true);
> can anybody help?
> thanks
Sunil
Previous Topic:Local jdk javadoc setup
Next Topic:How to update the elements of a Composite?
Current Time: Sun Aug 31 18:27:05 EDT 2025
Powered by FUDForum. Page generated in 0.03842 seconds
