Home » Eclipse Projects » Eclipse Platform » popup help
popup help [message #300081] Wed, 01 March 2006 11:29 Go to next message
Hi All,
I extended org.eclipse.ui.popupMenus but I want to know how I can
determine the object over which the user has clicked (in my case it is
file) and how I can determine if the file was saved after last
modifications in it.
Thank in advanced
Fred
Re: popup help [message #300343 is a reply to message #300081] Tue, 07 March 2006 16:19 Go to previous message
You should receive a selectionChanged callback on your IActionDelegate.
This should enable you to determine the object over which the user has
clicked.
The only way to find pending changes (that I know of) is from getting at an
instance of ISaveablePart somehow -- usually by reaching out for an editor.
I don't know of a quick way of finding an editor corresponding to an IFile,
but it should be possible using the methods on IWorkbenchPage.
cheers,
d.
Previous Topic:Customized editor very slow, what's wrong
Next Topic:How are menu contributions sorted
Current Time: Wed Nov 05 04:25:24 EST 2025
Powered by FUDForum. Page generated in 0.03156 seconds
