Home » Eclipse Projects » Buckminster dev » [buckminster-dev] how to change buckminster.temp property?
[buckminster-dev] how to change buckminster.temp property? [message #30000] Tue, 13 January 2009 19:59 Go to next message
Originally posted by: Mark.Addleman.ca.com
------_=_NextPart_001_01C975E3.6AE2D135
Content-Type: text/plain;
charset="us-ascii"
In headless Buckminster, the "buckminster.output" property can be
changed by placing "-D buckminster.output.root=3D" on the command line.
However, there doesn't seem to be a corresponding
"buckminster.temp.root" property that changes the "buckminster.temp"
property. I'd like to be able to run concurrent builds with
Buckminster, but I don't want all the builds to use the same temp
directory.
=20
=20
Content-Type: text/html;
charset="us-ascii"
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:m=3D"http://schemas.microsoft.com/office/2004/12/omml" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 12 (filtered medium)">
<style>
/* Font Definitions */
@font-face
{font-family:"Cambria Math";
panose-1:2 4 5 3 5 4 6 3 2 4;}
@font-face
{font-family:Calibri;
panose-1:2 15 5 2 2 2 4 3 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:11.0pt;
font-family:"Calibri","sans-serif";}
a:link, span.MsoHyperlink
{mso-style-priority:99;
color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
color:windowtext;}
..MsoChpDefault
{mso-style-type:export-only;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.0in 1.0in 1.0in;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 9]><xml>
<o:shapedefaults v:ext=3D"edit" spidmax=3D"1026" />
</xml><![endif]--><!--[if gte mso 9]><xml>
<o:shapelayout v:ext=3D"edit">
<o:idmap v:ext=3D"edit" data=3D"1" />
</o:shapelayout></xml><![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal>In headless Buckminster, the =
&#8220;buckminster.output&#8221;
property can be changed by placing &#8220;-D =
buckminster.output.root=3D&#8221; on
the command line.&nbsp; However, there doesn&#8217;t seem to be a =
corresponding
&#8220;buckminster.temp.root&#8221; property that changes the =
&#8220;buckminster.temp&#8221;
property.&nbsp; I&#8217;d like to be able to run concurrent builds with =
Buckminster,
but I don&#8217;t want all the builds to use the same temp =
directory.<o:p></o:p></p>
<p class=3DMsoNormal><o:p>&nbsp;</o:p></p>
</div>
</body>
</html>
------_=_NextPart_001_01C975E3.6AE2D135--
Re: [buckminster-dev] how to change buckminster.temp property? [message #30056 is a reply to message #30000] Wed, 14 January 2009 12:33 Go to previous message
Buckminster uses the value of the Java property 'java.io.tmpdir' as the
root for all temporary folders and you can change it by using the
option: -Djava.io.tmpdir=/the/temp/dir
Does that solve your problem?
Thomas Hallgren
Addleman, Mark J wrote:
> In headless Buckminster, the “buckminster.output” property can be
> changed by placing “-D buckminster.output.root=” on the command line.
> However, there doesn’t seem to be a corresponding
> “buckminster.temp.root” property that changes the “buckminster.temp”
> property. I’d like to be able to run concurrent builds with
> Buckminster, but I don’t want all the builds to use the same temp directory.
Previous Topic:[buckminster-dev] Resolving latest & specified subversion tag
Next Topic:Bucky Workspace : save action : Sort members excluding fields, enum constants, and initializers
Current Time: Tue Jul 08 15:46:19 EDT 2025
Powered by FUDForum. Page generated in 0.06862 seconds
