create a project from java file [message #298200] |
Thu, 26 January 2006 10:32  |
Originally posted by: maclacla.inwind.it
Hi all,
Can I create a new project with the eclipse API in a java program?
Before I have created the directory in my workspace and after that I need
to create the project in order to show the file in the workbench.
Can someone explane that or send me some code?
Please help me.
Thanks in advance.
max
Re: create a project from java file [message #298207 is a reply to message #298200] |
Thu, 26 January 2006 10:51   |
--------------040404000301000105080400
Max,
Maybe this will help:
public static IContainer findOrCreateContainer
(IPath path, boolean forceRefresh, IPath localLocation,
IProgressMonitor progressMonitor) throws CoreException
String projectName = path.segment(0);
IProjectDescription projectDescription =
ResourcesPlugin.getWorkspace().newProjectDescription(project Name);
projectDescription.setLocation(localLocation);
return findOrCreateContainer(path, forceRefresh,
projectDescription, progressMonitor);
(IPath path, boolean forceRefresh, IProjectDescription
projectDescription, IProgressMonitor progressMonitor) throws
CoreException
try
progressMonitor.beginTask("", path.segmentCount() + 3);
progressMonitor.subTask(CodeGenPlugin.getPlugin().getString( "_UI_ExaminingProject_message",
new Object [] { projectName }));
IWorkspace workspace = ResourcesPlugin.getWorkspace();
IProject project =
workspace.getRoot().getProject(path.segment(0));
if (forceRefresh)
project.refreshLocal(IResource.DEPTH_INFINITE, new
SubProgressMonitor(progressMonitor, 1));
else
progressMonitor.worked(1);
if (!project.exists())
project.create(projectDescription, new
project.open(new SubProgressMonitor(progressMonitor, 1));
else
project.open(new SubProgressMonitor(progressMonitor, 2));
IContainer container = project;
for (int i = 1, length = path.segmentCount(); i < length; ++ i)
IFolder folder = container.getFolder(new
Path(path.segment(i)));
if (!folder.exists())
folder.create(false, true, new
else
container = folder;
return container;
finally
progressMonitor.done();
max wrote:
> Hi all,
> need to create the project in order to show the file in the workbench.
> Please help me.
> Thanks in advance.
> max
<html>
<head>
http-equiv="Content-Type">
</head>
Max,<br>
<br>
Maybe this will help:<br>
<br>
<blockquote><small>
Re: create a project from java file [message #298301 is a reply to message #298262] |
Sat, 28 January 2006 04:23   |
Ed,
the scenario is this: we have to use some plugins created by our friends.
This plugins are editors to design UML diagrams.
For example I have this file : MyDiagram.drd (it's something like UML use
case diagram).
I'd need to create a Java program that allow to execute (and then load in
the workspace) this file. When my Java program start, Eclipse is
closed...so I'd need to open Eclipse and load the diagram.
Any help is welcome.
Best regards.
Max
Ed Merks wrote:
> Max,
> It sounds like you aren't really running in an initialized Eclipse
> environment. I'd need to understand more of your runtime context since
> the workspace is not normally closed. How are you running your
> application? (You'll maybe need to learn about how to run a headless
> Eclipse; try searching for that.)
> max wrote:
>> Hi Ed, thanks for your answer.
>> I create this class to call your method but when it call
>> catch the exception IllegalStartException workspace is closed.
>> Why? where I wrong?
>> Sorry, these are maybe stupid questions, but i am a new user of
>> Eclipse and i dont know so much of it.
>> Thanks again.
>> Max
>> public createProgect() {
>> IPath path = new Path("work"); IProgressMonitor
>> progressMonitor = new NullProgressMonitor();
>> try {
>> IContainer myContainer = findOrCreateContainer(path, true,
>> path, progressMonitor);
>> catch (CoreException e)
>> e.printStackTrace();
Re: create a project from java file [message #298302 is a reply to message #298301] |
Sat, 28 January 2006 11:07  |
Originally posted by: automatic.javalobby.org
The only time you get Workspace Closed is because you're trying to fire Eclipse-internals from a public static void main() method, or an application launched by right-clicking on it in Eclipse and doing 'Run as ... Java application'. You can *only* use the Eclipse internals if you're developing a bona-fine plugin and launching it via a 'Runtime workspace'.
Running a Java application from within Eclipse does *not* give you access to Eclipse's internals. The only way you get access to Eclipse's internals is by running as a plug-in and hosted within the Eclipse environment directly. My guess is that what you should do is create a plugin, then hook it up to some kind of Action, then launch a runtime workspace to test your plugin. When you're happy your plugin works, you can install it into your main Eclipse workspace to use for the future.
Alex.
FUDForum. Page generated in 0.07547 seconds
