Home » Eclipse Projects » Eclipse Platform » InputDialog getOkButton() and Dialog getButton(id) both returns null, why?
InputDialog getOkButton() and Dialog getButton(id) both returns null, why? [message #297550] Tue, 17 January 2006 05:11 Go to next message
Originally posted by: dozerox.gmail.com
I tried to change the text of the buttons in
org.eclipse.jface.dialogs.InputDialog. I made own InputDialog class that
had jface InputDialog as superclass and did a methods that should of
return the buttons. I tried both InputDialog class getOkButton() and
Dialog class getButton(id), but bot returns null. Here's what I tried:
import org.eclipse.jface.dialogs.IInputValidator;
import org.eclipse.jface.dialogs.InputDialog;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
public class myInputDialog extends InputDialog {
public myInputDialog(Shell arg0, String arg1,
String arg2, String arg3, IInputValidator arg4) {
super(arg0, arg1, arg2, arg3, arg4);
public Button getMyOkButton(){
return getOkButton();
public Button getMyButton(int id){
return super.getButton(id);
getMyButton method is called with: getMyButton(IDialogConstants.OK_ID);
but they both return null. Should it work this way?
I also tried to override the createButtonsForButtonBar method in
InputDialog and created the buttons my self like this:
protected void createButtonsForButtonBar(Composite parent) {
okButton = createButton(parent, IDialogConstants.OK_ID,
IDialogConstants.OK_LABEL, true);
cancelButton = createButton(parent, IDialogConstants.CANCEL_ID,
IDialogConstants.CANCEL_LABEL, false);
But by overriding the createButtonsForButtonBar method broke the
InputValidator of the InputDialog. I guess the text widget did not get
created when doing this, atleast the stacktraces pointed that way.
Anyways, any help on this would be much appreciated!
Re: InputDialog getOkButton() and Dialog getButton(id) both returns null, why? [message #297551 is a reply to message #297550] Tue, 17 January 2006 05:32 Go to previous message
Originally posted by: scheglov_ke.nlmk.ru
doze wrote:
You call these methods in wrong time.
Until open() (or create()) buttons are not created.
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Previous Topic:How can I set the position of the cursor in a TestEditor?
Next Topic:Best way for automated team checkout and update?
Current Time: Sun Nov 23 12:54:42 EST 2025
Powered by FUDForum. Page generated in 0.07003 seconds
