Home » Eclipse Projects » Eclipse Platform » help required in implementing a multipage(multiform editor)
help required in implementing a multipage(multiform editor) [message #297152] Tue, 10 January 2006 00:46
Originally posted by: nagrajhegde.yahoo.com
I need to create a multi-page editor for a xml file.
This editor should be somewhat like the plug-in xml editor , but will not be that complicated.
The user should be able to edit the xml file by hand and he should also be able to update it through an UI.
Can i get some sample code which explains everything including the model object which we use for storage.I am new to eclipse and hence i am not able to understand from where to start off. By looking at the code for the manifestEditor is very complicated and is made of many many classes having their long inheritance hierarchy.
I would require a tutorail on how to implement a multipage editor containing atmost 3 pages , with 1 page containing the raw xml and the other two containing the UI for the user to manipulate the xml.
Thanks & Regards
Nagraj
Previous Topic:CheckboxTableViewer: set the checkboxes programmatically
Next Topic:Regarding randomly generating a file name while creating a file using IFile
Current Time: Tue Jul 22 21:24:26 EDT 2025
Powered by FUDForum. Page generated in 0.02712 seconds
