| Please Help! Eclipse 3.1.1 suddenly not building any projects [message #296705] |
Fri, 30 December 2005 22:33  |
I've been struggling with this all day. I cleaned all my projects, but no
build automatically happened. I selected Project>Build All, but no building
happened.
I uninstalled Eclipse and reinstalled it, but this had no effect. Could the
problem be in the workspace some how? Most of my projects have not been
modified.
I have a lot of changes, but I cannot check them into cvs yet. I'm thinking
of creating a new workspace, checking out one project, and see if it will
build. If it does, then I could check out all the projects, manually merge
the changes in the old files into the new files. Yuk! This will take weeks
to do and very error prone.
Does anyone have any other suggestions?
Thank you in advance,
Don
| Re: Please Help! Eclipse 3.1.1 suddenly not building any projects [message #296706 is a reply to message #296705] |
Sat, 31 December 2005 03:52   |
Originally posted by: osadeh.gmail.com
Don Leckie wrote:
> happened.
> modified.
> Don
Trivial checklist, but if we had a dime for every time it happens ;-)
- Check the 'Problems' view to see if there's any problem preventing the
build.
- Make sure all files are in the build path (and not excluded somehow).
HTH,
Oren
| Re: Please Help! Eclipse 3.1.1 suddenly not building any projects [message #296712 is a reply to message #296706] |
Sat, 31 December 2005 23:05  |
Oren,
Thanks!!! I stumbled upon a cyclical build error in the problems pane when
I opened the project's plugin.xml file. I went to the Preferences/Build and
unchecked Cycle.
Hope you have a Happy New Year.
Thank you,
Don
"Oren Sadeh" <osadeh@gmail.com> wrote in message
news:dp5gqs$6e5$1@utils.eclipse.org...
> Don Leckie wrote:
>> no build automatically happened. I selected Project>Build All, but no
>> building happened.
>> the problem be in the workspace some how? Most of my projects have not
>> been modified.
>> thinking of creating a new workspace, checking out one project, and see
>> if it will build. If it does, then I could check out all the projects,
>> manually merge the changes in the old files into the new files. Yuk!
>> This will take weeks to do and very error prone.
>> Don
> build.
> HTH,
> Oren
FUDForum. Page generated in 0.04591 seconds
