Home » Eclipse Projects » Eclipse Platform » NoClassDefFoundError IProgressMonitor 3.2M4
NoClassDefFoundError IProgressMonitor 3.2M4 [message #296594] Tue, 27 December 2005 14:44 Go to next message
Originally posted by: kandkw.yahoo.com
I am creating a standalone Java Application. This problem appeared when I
upgraded from
3.1.1 to 3.2M4. I am running java (build 1.5.0_06-b05).
I did not see org/eclipse/core/runtime/IProgressMonitor in
org.eclipse.core.runtime_3.2.0.v20051208.jar
I looked at Bugzilla Bug 116520, but that did not seem applicable.
I probably have some setup error, but I don't know what it is. Any
suggestions or requests for more info are welcome.
I also get a popup saying "Could not find the main class. Program will exit"
The full text of the error is
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IProgressMonitor
Exception in thread "main"
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296619 is a reply to message #296594] Wed, 28 December 2005 04:25 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
How did you upgrade? Did you just unzip the contents over your previous install, or put it in a new location?
I'd expect there to be problems if you put it in the same place, or used the same workspace. Either try starting it with eclipse -clean (sometimes helps), or get rid of your old 3.1.1 install and then unzip 3.2 instead. You might have to delete the .metadata directory in your workspace too.
Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296657 is a reply to message #296619] Thu, 29 December 2005 10:41 Go to previous messageGo to next message
I removed the current eclipse install, deleted the source, removed .metadata
from the workspace,
resintalled eclipse 3.2M4, downloaded source from CVS, reconfigured
workspace.
Then I got the same problem.
Oddly enough if I run a .jnlp with the 3.1.1 jars (compiled against 3.2M4)
it works.
"Alex Blewitt" <automatic@javalobby.org> wrote in message
news:26660713.1135761933575.JavaMail.root@cp1.javalobby.org...
> Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296663 is a reply to message #296657] Thu, 29 December 2005 12:41 Go to previous messageGo to next message
I have both a 3.1.1 and 3.2M4 eclipse install, both pointed at the same
workspace. The only
difference is the jars in the classpath. Obviously I have two separate
versions of my
build.xml. Build and run work in 3.1.1, only build works in 3.2M4
The only change to the source code was to comment out a small section of
code that
set a background image (why I want 3.2M4).
The class that contains main extends ApplicationWindow
Is there anything else I could look at/do?
"OhPun" <kandkw@yahoo.com> wrote in message
news:dp1013$6rb$1@utils.eclipse.org...
>.metadata from the workspace,
> workspace.
> it works.
>> Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296674 is a reply to message #296663] Thu, 29 December 2005 18:14 Go to previous messageGo to next message
The problem is almost certainly that you're sharing a workspace between the 3.1.1 and 3.2 clients. The .metadata directory is something that stores plugin-specific data for each plugin, and these change in the major releases. Whilst it's possible that going from 3.1->3.2 will cause some of the data structures to be updated on demand, they certainly won't be downgradable if you then run the 3.1 system again.
Instead, it's much better if you have two separate workspaces (and hence separate .metadata directories); then, if you want to share projects between the two, don't put the project in the workspace but in a shared location outside of it. In other words, have something like:
Eclipse_3-1\workspace
Eclipse_3-2\workspace
Shared\MyProject
Shared\MyOtherProjecy
That way the .metadata won't be shared, which will certainly be the cause of some of your problems. Whether it fixes them all or not, I can't say.
Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296675 is a reply to message #296674] Thu, 29 December 2005 18:24 Go to previous messageGo to next message
Actually I don't care about 3.1.1. I'm using it because it works. I'd rather
upgrade to 3.2 and
leave 3.1.1 behind. But I can't do that until I prove the project will run
under 3.2
Actually the metadata is from 3.2 and I'm running 3.1.1. However the
question still remains,
after removing all .metadata and starting from scratch with 3.2, why does it
compile, but
produce NoClassDefFoundError IProgressMonitor when run?
I will try a separate workspace, but I suspect the same problem will happen
again. I will let you know
tomorrow.
news:17259543.1135898119802.JavaMail.root@cp1.javalobby.org...
> Shared\MyProject
> Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296701 is a reply to message #296663] Fri, 30 December 2005 17:00 Go to previous messageGo to next message
The only thing I can think is that there are a bunch of refactorings going on with the 3.2 codebase, and that some class that the IProgressManager depends on (or is being moved to) is now in some org.eclipse.equinox package instead. However, I doubt that's the reason for this.
It might help, once it's in 3.2, to do an update classpaths just to check everything is seemingly in the right place.
It could also be to do with the fact that some build/verify routines are a little more picky in 3.2 (for example, making sure that '.' is on the classpath for the Manifest.MF) but I don't know that this is likely to be cause in this case.
I'm running out of ideas here :-)
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296703 is a reply to message #296674] Fri, 30 December 2005 18:00 Go to previous messageGo to next message
I tried two separate workspaces. 3.1.1 works perfectly, 3.2 gives me the
same error.
> Shared\MyProject
> Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296714 is a reply to message #296701] Sun, 01 January 2006 08:24 Go to previous messageGo to next message
I might have been leading you up the wrong tree. It seems that the IProgressMonitor has been shifted into the org.eclipse.equinox.common plugin, although in the same package as previously:
<a href=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.equinox .common/src/org/eclipse/core/runtime/IProgressMonitor.java?r ev=HEAD&content-type=text/vnd.viewcvs-markup">IProgressMonitor.java</a>.
You should ensure that in the 3.2 world, you add the org.eclipse.equinox.common plugin as part of your Manifest.MF dependencies; though TBH I expected that if you were dependent on org.eclipse.core.runtime before, that the dependency would be re-exported to this plugin so it wouldn't be necessary.
Does that help?
Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296818 is a reply to message #296714] Tue, 03 January 2006 10:33 Go to previous messageGo to next message
That's probably his problem ... his original post says he's doing a
stand-alone java program, which (I assume) means java+SWT+JFace jars.
He needs to find the jar that IProgressMonitor has been moved into.
That was one of the reasons the runtime was broken up, so JFace could
depend on a little jar instead of the core.runtime jar.
Later,
PW
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #296856 is a reply to message #296714] Tue, 03 January 2006 13:38 Go to previous messageGo to next message
Thanks, this solved my problem.
news:5133044.1136121926511.JavaMail.root@cp1.javalobby.org...
> <a
> Does that help?
> Alex.
Re: NoClassDefFoundError IProgressMonitor 3.2M4 [message #297025 is a reply to message #296856] Fri, 06 January 2006 11:58 Go to previous message
I've raised this as <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=122935">Bug 122935</a> if you want to track progress.
Alex.
Previous Topic:Add submenu to MenuManager?
Next Topic:Problem with buttons in console.
Current Time: Sun Aug 31 18:31:58 EDT 2025
Powered by FUDForum. Page generated in 0.05311 seconds
