Error running eclipse on FC3 AMD64 [message #29725] |
Mon, 28 February 2005 07:36  |
Originally posted by: james.dimmock.gmail.com
I can't seem to get eclipse running on Fedora Core 3 64 bit edition. When
running I get an error and the log reads as follows:
I have installed the java jdk 1.4.2_07 and the commands 'java' and 'javac'
work from the terminal. The files that are supposedly non-existent do
exist in the specified locations so i'm not sure why the error occurs. Do
I need to install gtk / how do I verify whether I have it installed?
!SESSION Feb 28, 2005 12:28:11.498
eclipse.buildId=M200409161125
java.version=1.4.2_07
BootLoader constants: OS=linux, ARCH=amd64, WS=gtk, NL=en_GB
!ENTRY org.eclipse.osgi Feb 28, 2005 12:28:11.499
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError:
/home/jamesdi/Downloads/eclipse/plugins/org.eclipse.swt.gtk6 4_3.0.1/os/linux/amd64/libswt-pi-gtk-3063.so:
cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1495)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:118)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:268)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:153)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:122)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:72)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688
Re: Error running eclipse on FC3 AMD64 [message #29737 is a reply to message #29729] |
Mon, 28 February 2005 11:36  |
Many thanks Jeff, i installed the 64 bit edition of JDK 1.5 and eclipse
now runs as expected (so far ;)).
James
Jeff Myers wrote:
> James,
> Make sure you're running with Sun's 64 bit linux JRE. I can tell you're
> using a 32 bit JRE because Sun has only released a 64 bit version of JRE
> 1.5 (and you're using 1.4.2)
> Hope this helps,
> - Jeff
>> When running I get an error and the log reads as follows:
>> 'javac' work from the terminal. The files that are supposedly
>> non-existent do exist in the specified locations so i'm not sure why the
>> error occurs. Do I need to install gtk / how do I verify whether I have
>> it installed?
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
FUDForum. Page generated in 0.12347 seconds
