| Re: programmatically re-arrange the editors inside the editors view [message #296788 is a reply to message #296441] |
Tue, 03 January 2006 09:10  |
Alex K wrote:
> I want to be able to open two editors and place them next to eachother
> programmatically. In Eclipse 3.1 you can re-arrange the editors next to each
> other on the left and right side (for example for comparing two files). You
> can also place two editors top and bottom or four editors one in each corner
Ah, move open editors to new editor stacks ...
I've seen examples of programmitically doing this in some tests, but
IIRC it was accomplished using internal APIs and faking a drag and drop.
The tests are in the org.eclipse.ui.tests plugin, available from CVS.
Later,
PW
FUDForum. Page generated in 0.05055 seconds
