Home » Eclipse Projects » Eclipse Platform » Read-only Launch Configurations
Read-only Launch Configurations [message #296023] Tue, 13 December 2005 19:37 Go to next message
Originally posted by: s_gutz.yahoo.com
I have my own launcher that sits in the Run... menu and it works fine for
creating/editing/removing configurations. However I would like to be able
to create hard-coded launch configurations that are marked as read-only, so
that cannot be removed or changed. I sifted through the code and it doesn't
look like this is possible, but I can't belive this it true.
Anyone know how to create non-editable launch configurations?
Steve
Re: Read-only Launch Configurations [message #296031 is a reply to message #296023] Tue, 13 December 2005 23:54 Go to previous message
Originally posted by: sunil_kamath.nohotspammail.com
> for creating/editing/removing configurations. However I would like
> to be able to create hard-coded launch configurations that are marked
> as read-only, so that cannot be removed or changed. I sifted through
> the code and it doesn't look like this is possible, but I can't
Change your launch configuration tabs so that they are read-only if a
certain launch configuration attribute is set.
The launch config can still be removed, though.
Sunil
Previous Topic:how to disable the save as menu
Next Topic:errors when extending org.eclipse.ui.newWizards
Current Time: Thu Oct 30 22:54:03 EDT 2025
Powered by FUDForum. Page generated in 0.04573 seconds
