Home » Eclipse Projects » Eclipse Platform » How to open two view in eclipse at one go?
How to open two view in eclipse at one go? [message #294583] Mon, 14 November 2005 11:17 Go to next message
Originally posted by: seshasai.aesv.softwareag.com
Hi All
I need to just select one option in the
windows>>show view>>Others and select one option then I should provide me with
two views
alternatively can I call one view inside another view so If I do some
chnages in one view it effects another view.
Thanks in advance
venkat
Re: How to open two view in eclipse at one go? [message #294592 is a reply to message #294583] Mon, 14 November 2005 12:23 Go to previous messageGo to next message
> should provide me with two views
Please restate the above question a little clearly.
> If I do some chnages in one view it effects another view
You can get handle to another view from some view as follows ..
class FirstViewPart extends ViewPart
	private SecondViewPart getSecondView()
		return getSite().getPage().findView(SecondViewPart.ID);
class SecondViewPart extends ViewPart
	/* view id as declared in plugin.xml */
	public static final String ID = "com.xyz.SecondViewPart";
Venkataramana M
Re: How to open two view in eclipse at one go? [message #294614 is a reply to message #294592] Tue, 15 November 2005 03:59 Go to previous messageGo to next message
Hi Venkataramana
thanks for answering second part of the question.
What I want was when one selects only one option for a view,then I should
see two tab views,(normalyy only one view opens)
regards
venkat
Re: How to open two view in eclipse at one go? [message #294615 is a reply to message #294614] Tue, 15 November 2005 04:12 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
You have to open the second view programatically. You could do this in
the init method of the first view.
Stefan
venkat wrote:
> Hi Venkataramana thanks for answering second part of the question.
> should see two tab views,(normalyy only one view opens)
> regards
> venkat
Re: How to open two view in eclipse at one go? [message #294620 is a reply to message #294615] Tue, 15 November 2005 06:30 Go to previous message
To complement Stefan's post, the implementation could be like this ..
class FirstViewPart ..
	public void init(IViewSite site) throws PartInitException
		super.init(site);
		/* open second view */
		getSite().getPage().showView(SecondViewPart.ID, IWorkbenchPage.VIEW_VISIBLE/*VIEW_ACTIVATE*/);
Venkataramana M
Previous Topic:Decorator startup...
Next Topic:Correction on org.eclipse.target ; ResourcesPlugin problem
Current Time: Mon Jul 14 20:49:53 EDT 2025
Powered by FUDForum. Page generated in 0.03637 seconds
