Home » Eclipse Projects » Eclipse Platform » How to use the extension-point org.eclipse.ui.keywords?
How to use the extension-point org.eclipse.ui.keywords? [message #294152] Fri, 04 November 2005 09:53 Go to next message
The ext-point docs do not explain it. I only had the idea that this ext-point could be useful
because in https://bugs.eclipse.org/bugs/show_bug.cgi?id=106858#c3 Nick Edgar said that if one
extended this ext.-point, one could get the Prefs-Dialog "filter" to find one's own Pref-Page. But
doing the obvious thing does not work at all:
<extension
id="biz.bux.png.saw2.keywords"
point="org.eclipse.ui.keywords">
<keyword
id="biz.bux.png.saw2.keyword1"
label="type-system"/>
<keyword
id="biz.bux.png.saw2.keyword2"
label="Types"/>
</extension>
<extension
point="org.eclipse.ui.preferencePages">
<page
class="biz.bux.png.saw2.Preferences"
id="biz.bux.png.saw2.prefPage"
name="My Preferences">
<keywordReference id="biz.bux.png.saw2.keywords"/>
</page>
</extension>
When entering "Types" or "type-system" into the filter, my pref-page is not found.
So, how do I do it?
thanks,
Paul
Re: How to use the extension-point org.eclipse.ui.keywords? [message #294157 is a reply to message #294152] Fri, 04 November 2005 10:23 Go to previous messageGo to next message
Originally posted by: douglas.pollock.magma.ca
Paul Keyser wrote:
> <extension
> <keyword
> <keyword
> label="Types"/>
> </extension>
> <extension
> <page
Replace the above with:
<keywordReference id="biz.bux.png.saw2.keyword1"/>
<keywordReference id="biz.bux.png.saw2.keyword2"/>
> </page>
> </extension>
cheers,
d.
Re: How to use the extension-point org.eclipse.ui.keywords? [message #294160 is a reply to message #294157] Fri, 04 November 2005 10:30 Go to previous message
Excellent! I knew I was doing something wrong that would be simple to fix, just did not think of
that fix. (Maybe the docco could be clarified, just a little bit?)
thanks,
paul
Previous Topic:Java version?
Next Topic:Java EMF Model (1.1.0) requires feature "org.eclipse.jdt (3.1.0)", or compatible
Current Time: Tue Jul 15 18:27:46 EDT 2025
Powered by FUDForum. Page generated in 0.02894 seconds
