Bundle Update@ ...was not resolve conflicts, using an extension location [message #293143] |
Tue, 18 October 2005 18:08 |
Please forgive if this isn't the right forum, but perhaps you can direct
me to the correct one.
The MyEclipse product is installed, in a separate extension location.
I'm attempting to install tptp in another separate extension location.
Both require the EMF, XSD, (GEF) plugins, but different versions. For
example, MyEclipse comes bundled with version 2.1.0, and tptp4.0.1
indicates it needs version 2.1.1. After I have installed tptp4.0.1, with
EMF and XSD 2.1.1, and then launch Eclipse 3.1.1, I see the following
messages in the error log: (I get a lot of these errors.)
!SESSION 2005-10-18 17:11:21.551
eclipse.buildId=I20050627-1435
java.version=1.5.0_05
Framework arguments: -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -showlocation -debug
!ENTRY org.eclipse.osgi 2005-10-18 17:11:24.665
!MESSAGE Bundle update@../../../../Program
Files/MyEclipse/eclipse/plugins/org.eclipse.emf.ecore.edit_2 .1.0/ [2949]
was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-10-18 17:11:24.665
!MESSAGE Bundle
update@.. /../../common-plugins/3.1-only/eclipse/plugins/org.eclipse.e mf.ecore.edit_2.1.1.jar
was picked instead.
Files/MyEclipse/eclipse/plugins/org.eclipse.emf.edit_2.1.0/ [2956] was
not resolved.
!SUBENTRY 1 org.eclipse.osgi 2005-10-18 17:11:24.675
!MESSAGE Bundle
update@.. /../../common-plugins/3.1-only/eclipse/plugins/org.eclipse.e mf.edit_2.1.1.jar
was picked instead.
Granted it picked a plugin version to use, but I'm unsure just how
different the code is for versions 2.1.0 vs 2.1.1.
Is there a way of having different products or plugin versions to
reference and load the correct versions?
Do you have to have some type of extension path naming stradegy to allow
extension plugins to load in some order?
frank
FUDForum. Page generated in 0.03927 seconds
