Home » Eclipse Projects » Eclipse Platform » How can a user easily enter input of type DATE ?
How can a user easily enter input of type DATE ? [message #292625] Sat, 08 October 2005 17:06 Go to next message
Originally posted by: bobruney.gmx.net
iŽm currently coding a programm, which needs the user to enter a valid
Date and Time into a SWT input form.
I wonder how i can do this best, cause the Date dataclass is quite complex
and i canŽt figure out how to enable the user to letting him/her enter a
date without getting error messages all the time, because the date is not
in the right format.
Is there maybe a widget for stuff like this floating round? (like the file
choser dialog)
Or has anybody any input on how to do this best?
Thanks a lot for your time and any answer
Andreas
Re: How can a user easily enter input of type DATE ? [message #292648 is a reply to message #292625] Mon, 10 October 2005 05:43 Go to previous messageGo to next message
Originally posted by: eclipse.bettsockentraeger.de
These are just a few I found by searching the web.
http://swtcalendar.sourceforge.net/index.html (this one is nice and
brings all you need)
http://gface.sourceforge.net/ (this one I haven't tested but I included
anyway)
HTH
Stefan
Andreas wrote:
> complex and i canŽt figure out how to enable the user to letting him/her
> enter a date without getting error messages all the time, because the
> date is not in the right format.
> file choser dialog)
> Andreas
Re: How can a user easily enter input of type DATE ? [message #292695 is a reply to message #292648] Tue, 11 October 2005 09:11 Go to previous messageGo to next message
also see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet179.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
Grant
"Stefan Langer" <eclipse@bettsockentraeger.de> wrote in message
news:434A37C8.9050807@bettsockentraeger.de...
> Hi
> anyway)
> HTH
> Stefan
> Andreas wrote:
> > Hi,
> > i
Re: How can a user easily enter input of type DATE ? [message #292705 is a reply to message #292695] Tue, 11 October 2005 10:05 Go to previous message
Originally posted by: arne.anka.ginguppin.de
> also see
unsatisfying. a control (probably Text) haveing the local separators and
refusing everything else than numbers would be far more convenient to the
user.
e g (we assume german date of the format dd.mm.yyyy)
[__.__.____] if the user types anything else than numbers it's ignored, if
the numbers given are unreasonable (days above 31 and month above 12)
the're ignored.
i played around with a Text and a ModifyListener (the ModifyListener
called in turn an IInputValidator and bothered with an error-messafe in
the StatusLine as long as the Text's text did not match a given pattern)
but it was still not satisfying. so i switched to swt-datepicker
(http://sourceforge.net/projects/swt-datepicker/) using the
DatepcikerCombo as input but it's still not what i want.
Previous Topic:Best Practice: implementing a "Control View" for another view
Next Topic:How to patch a plugin?
Current Time: Sat Nov 22 11:36:31 EST 2025
Powered by FUDForum. Page generated in 0.04084 seconds
