Home » Eclipse Projects » Eclipse Platform » refresh a project
refresh a project [message #292444] Thu, 06 October 2005 11:45 Go to next message
Originally posted by: pbeagan.yahoo_dontspamme_.com
What is the code snippet to refresh a project? I have an IPath to a file
in the project.
I have code that creates a new IFile in a project, saves to the root of that
project. I then immediately want to display the contents of this file in
an editor using IDE.openEditor(..). Problem is : Eclipse thinks the file
does not exist even though it is in the file system. Maybe there is
something I can do besides programmatically refresh the project. Any
ideas? Thanks.
sorry if this has been asked before.
Re: refresh a project [message #292996 is a reply to message #292444] Fri, 14 October 2005 11:37 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
If you created the IFile using IFile.create(...) then no refresh is
required. If you created the file some other way, such as with
java.io.File, then a refresh is required. Here is a snippet, given an
IProject, and an IPath to the file in that project:
IPath pathToFile = ...;//your path to the file
IFile file = project.getFile(pathToFile);
file.refreshLocal(IResource.DEPTH_ZERO, null);
> in the project.
> ideas? Thanks.
Re: refresh a project [message #293002 is a reply to message #292996] Fri, 14 October 2005 14:00 Go to previous messageGo to next message
I have similar problem. But the refreshLocal() did not help me.
Please see below for details of my problem
HI,
I have implemented an action that creates a new file under a project and
tries to open it in an UMLEditor. This action is throwing a "Wrapped
exception"
What I have done is -
1) In the action, I am creating a new file under a project
IFile file = project.getFile( fileName );
file.create( null, false, null );
2) Open the new file in an UMLEditor
IEditorPart editorPart = IDE.openEditor( page, file, true );
3) The control comes back to MyEditor.setInput(). In this method I am
getting ResourceSet of the project and then trying to get the resource for
the file
IFile file = ( (IFileEditorInput) input ).getFile();
URI uri = URI.createPlatformResourceURI( file.getFullPath().toString() );
resourceSet.getResource( uri, true );
4) The getResource() method throws Wrapped Exception complaining that the
file that I created is not local. See the error trace below.
Is there anything that I am missing? How do I get rid of this problem?
Brahma
Wrapped exception
org.eclipse.core.internal.resources.ResourceException: Resource
/Ford/Appearance.uml is not local.
org.eclipse.core.internal.resources.Resource.checkLocal(Reso urce.java:316)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:293)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:283)
org.eclipse.emf.ecore.resource.impl.URIConverterImpl$Workben chHelper.createPlatformResourceInputStream(URIConverterImpl. java:195)
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceInputStream(URIConverterImpl.java:533)
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:442)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:829)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:349)
com.bmide.model.util.TcResourceSetImpl.getResource(TcResourc eSetImpl.java:66)
at com.bmide.uml.ui.editor.UMLEditor.testLoad(UMLEditor.java:41 3)
at com.bmide.uml.ui.editor.UMLEditor.setInput(UMLEditor.java:34 5)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:292)
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:773)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:572)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:365)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:258)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1216)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:944)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:939)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2535)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1819)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2566)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 515)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1514 )
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1263 )
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1258)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1512)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 491)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1374 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1318)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:700)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: refresh a project [message #293003 is a reply to message #293002] Fri, 14 October 2005 14:07 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
The documentation for file.create says if you pass "null" in for the
input stream then the file will not be local.
Null for input stream does not mean create an empty file!
You need to supply an InputStream that immediately returns end of input
so that you can create an empty file.
> exception"
> the file that I created is not local. See the error trace below.
Rich Kulp
Previous Topic:popup menu in eclipse plugin
Next Topic:Plugin ClassLoader issue
Current Time: Sun Oct 26 16:48:41 EDT 2025
Powered by FUDForum. Page generated in 0.03805 seconds
