Home » Eclipse Projects » Remote Application Platform (RAP) » error at initial request
error at initial request [message #29137] Thu, 31 May 2007 03:29 Go to next message
Originally posted by: gregor.ambrozic.gmail.com
I just updated the RAP projects and I am getting errors when accessing
http://localhost:9090/rap (although the server seems to start OK).
31/05/2007 09:15:31 org.mortbay.jetty.servlet.ServletHandler handle
WARNING: EXCEPTION
javax.servlet.ServletException: Plug-in org.eclipse.rap.ui.workbench was
unable to load class org.eclipse.ui.internal.servlet.RequestHandler.
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.initializeDelegate(ServletManager.java:198)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:179)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:109)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:280)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Re: error at initial request [message #29543 is a reply to message #29137] Thu, 31 May 2007 17:47 Go to previous message
Originally posted by: oberhack.softwarefabrik.net
Hi Gregor,
had the same problem. Changing the startlevel to 1 for the
eclipse.core.runtime plugin solved the problem for me...
Andreas
"Gregor Ambrozic" <gregor.ambrozic@gmail.com> schrieb im Newsbeitrag
news:fa465d2d6bf8379809480b513adadf90$1@www.eclipse.org...
> WARNING: EXCEPTION javax.servlet.ServletException: Plug-in
> org.eclipse.rap.ui.workbench was unable to load class
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Hide a ViewPart
Next Topic:Logging
Current Time: Tue Nov 18 17:56:21 EST 2025
Powered by FUDForum. Page generated in 0.03491 seconds
