| Getting trace infromation? [message #29058] |
Wed, 31 August 2005 14:19  |
Originally posted by: dacostae.ciudad.com.ar
Hi everybody.
I'm trying to do the following thing: I need to make my plug-in that
analyze the trace of an excecution to detect posible causes of malfunction
based on components' responsabilities.
The questions are:
- How can I get the trace information? (Information that appears in the
UML2 Interaction Diagram view would be enough)
- How can I choose/generate/change a Profilig Set (Run Configuration)
programmaticaly from my plug-in?
Any help will be wellcomed, extension points to look at, api info,
examples, suggestions, ideas, anything.
thanks a lot!
Enrique
| Re: Getting trace infromation? [message #29161 is a reply to message #29058] |
Thu, 01 September 2005 12:19   |
Originally posted by: Navid_Mehregani-_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 0059A2C58525706F_=
Content-Type: text/plain; charset="US-ASCII"
Hi Enrique,
I'm not exactly sure why you want to change the profiling sets
"programmatically" from your plug-in. That's not a trivial thing to do
and I
don't recommend it. However, if you do find it necessary, look into the
org.eclipse.hyades.ui and org.eclipse.hyades.execution.trace modules.
If you debug the PDCoreUtil class, you'll see how the options are being
setup and passed to the launch/attach functions.
It should be possible for you to generate the UML2 interaction diagrams
for your plug-in by profiling a runtime instance of your workbench. You'll
need to
select the "Execution History - Full Graphical Detail" profiling set to
get the UML2 diagrams. Profiling the workbench can be a bit slow,
especially if you select
the graphical options so make sure you filter out any of the data you're
not interested in.
Navid Mehregani
IBM Canada
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi Enrique,</font>
<br>
<br><font size=2 face="sans-serif">I'm not exactly sure why you want to
change the profiling sets "programmatically" from your plug-in.
That's not a trivial thing to do and I</font>
<br><font size=2 face="sans-serif">don't recommend it. However, if
you do find it necessary, look into the org.eclipse.hyades.ui and org.eclipse.hyades.execution.trace
modules.</font>
<br><font size=2 face="sans-serif">If you debug the PDCoreUtil class, you'll
see how the options are being setup and passed to the launch/attach functions.</font>
<br>
<br><font size=2 face="sans-serif">It should be possible for you to generate
the UML2 interaction diagrams for your plug-in by profiling a runtime instance
of your workbench. You'll need to</font>
<br><font size=2 face="sans-serif">select the "Execution History -
Full Graphical Detail" profiling set to get the UML2 diagrams. Profiling
the workbench can be a bit slow, especially if you select</font>
<br><font size=2 face="sans-serif">the graphical options so make sure you
filter out any of the data you're not interested in.</font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
<br><font size=2 face="sans-serif">IBM Canada</font>
--=_alternative 0059A2C58525706F_=--
| Re: Getting trace infromation? [message #29351 is a reply to message #29161] |
Thu, 01 September 2005 17:51  |
------=_NextPart_000_0064_01C5AF1D.CA34D6A0
charset="iso-8859-1"
Enrique,
If you want to get access to the =
org.eclipse.hyades.models.trace.TRCProcess (which is the root of the the =
profiling trace used in the trace views including interaction diagrams) =
you could take a look at =
/org.eclipse.hyades.use.cases/src/org/eclipse/hyades/use/cas es/junit/mode=
ls/test/TraceAndLogModelTest.java - loadTraceModel method - for a =
standalone example or if you run the TPTP UI you could listen for =
different kinds of selection change events that come from the Profiling =
Monitor or the other trace views (see =
org.eclipse.hyades.trace.ui.UIPlugin add* methods).
Please let me know if you need more info.
Marius
<Navid_Mehregani-_nmehrega@ca.ibm.com> wrote in message =
news:df79ln$o68$1@news.eclipse.org...
Hi Enrique,=20
I'm not exactly sure why you want to change the profiling sets =
"programmatically" from your plug-in. That's not a trivial thing to do =
and I=20
don't recommend it. However, if you do find it necessary, look into =
the org.eclipse.hyades.ui and org.eclipse.hyades.execution.trace =
modules.=20
If you debug the PDCoreUtil class, you'll see how the options are =
being setup and passed to the launch/attach functions.=20
It should be possible for you to generate the UML2 interaction =
diagrams for your plug-in by profiling a runtime instance of your =
workbench. You'll need to=20
select the "Execution History - Full Graphical Detail" profiling set =
to get the UML2 diagrams. Profiling the workbench can be a bit slow, =
especially if you select=20
the graphical options so make sure you filter out any of the data =
you're not interested in.=20
Navid Mehregani=20
IBM Canada
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1515" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV>
<DIV>Enrique,</DIV>
<DIV> </DIV>
<DIV>If you want to get access to the =
org.eclipse.hyades.models.trace.TRCProcess=20
(which is the root of the the profiling trace used in the trace views =
including=20
interaction diagrams) you could take a look at=20
ls/test/TraceAndLogModelTest.java=20
- loadTraceModel method - for a standalone example or if you run the =
TPTP UI you=20
could listen for different kinds of selection change events that come =
from the=20
Profiling Monitor or the other trace views (see=20
org.eclipse.hyades.trace.ui.UIPlugin add* methods).</DIV>
<DIV> </DIV>
<DIV>Please let me know if you need more info.</DIV>
<DIV> </DIV>
<DIV>Regards,</DIV>
<DIV>Marius</DIV></DIV>
<BLOCKQUOTE=20
<DIV><<A=20
href=3D"mailto:Navid_Mehregani-_nmehrega@ca.ibm.com">Navid_Mehregani-_nme=
hrega@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:df79ln$o68$1@news.eclipse.org">news:df79ln$o68$1@news.eclips=
e.org</A>...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>Hi Enrique,</FONT> <BR><BR><FONT =
face=3Dsans-serif=20
size=3D2>I'm not exactly sure why you want to change the profiling =
sets=20
"programmatically" from your plug-in. That's not a trivial thing =
to do=20
and I</FONT> <BR><FONT face=3Dsans-serif size=3D2>don't recommend it.=20
However, if you do find it necessary, look into the=20
modules.</FONT>=20
<BR><FONT face=3Dsans-serif size=3D2>If you debug the PDCoreUtil =
class, you'll see=20
how the options are being setup and passed to the launch/attach=20
functions.</FONT> <BR><BR><FONT face=3Dsans-serif size=3D2>It should =
be possible=20
for you to generate the UML2 interaction diagrams for your plug-in by=20
profiling a runtime instance of your workbench. You'll need =
to</FONT>=20
<BR><FONT face=3Dsans-serif size=3D2>select the "Execution History - =
Full=20
Graphical Detail" profiling set to get the UML2 diagrams. =
Profiling the=20
workbench can be a bit slow, especially if you select</FONT> <BR><FONT =
face=3Dsans-serif size=3D2>the graphical options so make sure you =
filter out any=20
of the data you're not interested in.</FONT> <BR><BR><FONT =
size=3D2>Navid Mehregani</FONT> <BR><FONT face=3Dsans-serif =
size=3D2>IBM=20
Canada</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0064_01C5AF1D.CA34D6A0--
FUDForum. Page generated in 0.03554 seconds
