Home » Language IDEs » AspectJ » AJDT install problem
AJDT install problem [message #29048] Tue, 30 December 2003 12:29 Go to next message
Originally posted by: avishay_balderman.bmc.com
I am running Eclipse 3.0 on Windows.
After unziping the needed jars/zip I have the below directiry struture.
But hte plugin is not working (no hint that eclipse is aware to aspects)
Pleasee help
Avishay balderman
Install details:
1)
Files in <ECLIPSE_HOME>\features\org.eclipse.aspectj_1.1.4:
12\30\2003 05:52p <DIR> .
12\30\2003 05:52p <DIR> ..
09\22\2003 04:21p 5,086 aspectjLogo.gif
09\22\2003 04:21p 15,172 cpl-v10.html
09\22\2003 04:21p 5,517 feature.properties
09\22\2003 04:21p 1,673 feature.xml
09\22\2003 04:21p 4,796 license.html
12\30\2003 05:52p <DIR> META-INF
2)
Files in <ECLIPSE_HOME>\plugins\org.eclipse.aspectj_1.1.4:
12\30\2003 07:06p <DIR> .
12\30\2003 07:06p <DIR> ..
09\22\2003 04:21p 1,944 about.html
09\22\2003 04:27p 235,868 ajdt.jar
09\22\2003 04:21p 167,653 ajdtsrc.jar
09\22\2003 04:21p 5,194 aspectj_code_templates.xml
12\30\2003 07:06p <DIR> doc
09\22\2003 04:21p 22,001 faq.html
12\30\2003 07:06p <DIR> icons
12\30\2003 07:06p <DIR> lib
12\30\2003 07:06p <DIR> META-INF
09\22\2003 04:21p 1,396 plugin.properties
09\22\2003 04:21p 16,792 plugin.xml
09\22\2003 04:21p 432 README.html
12\30\2003 07:06p <DIR> releaseNotes
09\22\2003 04:21p 178 toc.xml
09\22\2003 04:21p 271 toc_ajdt.xml
09\22\2003 04:21p 1,010 toc_ajdtuguide.xml
09\22\2003 04:21p 8,630 toc_ajprogguide.xml
09\22\2003 04:21p 581 toc_aspectj.xml
3)
Files in <ECLIPSE_HOME>\plugins\org.aspectj.ajde_1.1.4:
12\30\2003 07:14p <DIR> .
12\30\2003 07:14p <DIR> ..
09\22\2003 04:21p 1,054,765 ajde.jar
09\22\2003 04:21p 1,999 ajde.jardesc
09\22\2003 04:21p 29,329 aspectjrt.jar
09\22\2003 04:21p 6,147,361 aspectjtools.jar
09\22\2003 04:21p 491,281 bcel.jar
12\30\2003 07:14p <DIR> doc
12\30\2003 07:14p <DIR> icons
12\30\2003 07:14p <DIR> META-INF
09\22\2003 04:21p 1,356 plugin.xml
4)
Files in <ECLIPSE_HOME>\plugins\org.eclipse.ajdt.ui_0.6.4:
12/30/2003 07:06p <DIR> .
12/30/2003 07:06p <DIR> ..
09/22/2003 04:21p 1,944 about.html
09/22/2003 04:27p 235,868 ajdt.jar
09/22/2003 04:21p 167,653 ajdtsrc.jar
09/22/2003 04:21p 5,194 aspectj_code_templates.xml
12/30/2003 07:06p <DIR> doc
09/22/2003 04:21p 22,001 faq.html
12/30/2003 07:06p <DIR> icons
12/30/2003 07:06p <DIR> lib
12/30/2003 07:06p <DIR> META-INF
09/22/2003 04:21p 1,396 plugin.properties
09/22/2003 04:21p 16,792 plugin.xml
09/22/2003 04:21p 432 README.html
12/30/2003 07:06p <DIR> releaseNotes
09/22/2003 04:21p 178 toc.xml
09/22/2003 04:21p 271 toc_ajdt.xml
09/22/2003 04:21p 1,010 toc_ajdtuguide.xml
09/22/2003 04:21p 8,630 toc_ajprogguide.xml
09/22/2003 04:21p 581 toc_aspectj.xml
Re: AJDT install problem [message #30302 is a reply to message #29048] Thu, 05 February 2004 08:16 Go to previous message
AJDT won't work with Eclipse 3.0 M5 or M6 due to platform
changings (Remember Eclipse 3.0 is still under development).
Martin (Kersten)
"Avishay" <avishay_balderman@bmc.com> schrieb im Newsbeitrag
news:bssck1$hqo$1@eclipse.org...
> Hi
> Pleasee help
> Thanks
> Avishay balderman
> Install details:
> 1)
> 2)
> 3)
> 4)
Re: AJDT install problem [message #574604 is a reply to message #29048] Thu, 05 February 2004 08:16 Go to previous message
Martin (Kersten)
> Hi
> Pleasee help
> Thanks
> Avishay balderman
> Install details:
> 1)
> 2)
> 3)
> 4)
Previous Topic:Problem in default.lst "Use relative paths only, omitting..."
Next Topic:-> Can anyone add a note about the M5/M6 incompatibility issus
Current Time: Sat Nov 08 19:00:14 EST 2025
Powered by FUDForum. Page generated in 0.03225 seconds
