Home » Eclipse Projects » Eclipse Platform » ClassNotFoundException with new .jar - but old one works???
ClassNotFoundException with new .jar - but old one works??? [message #290105] |
Thu, 18 August 2005 11:57  |
Originally posted by: dbt.acwanet.com
I have a couple of applications that load SQL connectors to transfer
data from a DB2 database to a MySQL database. I created one several
months ago that works fine. But now, when I try to create a new one, I
get a ClassNotFoundException on my Class.forName("<dbdriver>") line.
The drivers are in the same folder as the jar that is created, so that
shouldn't be the issue. What's odd is that I can take the jar that I
created several months ago, and it runs fine. I then take the same code
(absolutely no changes), create a new jar, and it bombs. I'm fairly new
to Java and Eclipse, so I'm not sure where to start.
I had done an upgrade from Eclipse 3.0 to 3.1, but even when I go back
to 3.0 and create a simple test program, it has the same problem.
Any ideas? Where do I even start?
Re: ClassNotFoundException with new .jar - but old one works??? [message #290108 is a reply to message #290105] |
Thu, 18 August 2005 12:14   |
Originally posted by: sunil_kamath.nohotspammail.com
"DBT" <dbt@acwanet.com> wrote in message
news:de2b77$ks1$1@news.eclipse.org...
>I have a couple of applications that load SQL connectors to transfer data
>from a DB2 database to a MySQL database. I created one several months ago
>that works fine. But now, when I try to create a new one, I get a
>ClassNotFoundException on my Class.forName("<dbdriver>") line. The drivers
>are in the same folder as the jar that is created, so that shouldn't be the
>issue. What's odd is that I can take the jar that I created several months
>ago, and it runs fine. I then take the same code (absolutely no changes),
>create a new jar, and it bombs. I'm fairly new to Java and Eclipse, so I'm
> I had done an upgrade from Eclipse 3.0 to 3.1, but even when I go back to
In the plugin.xml editor, go to the Runtime tab and make sure the driver
jars are in the plugin classpath.
Sunil
Re: ClassNotFoundException with new .jar - but old one works??? [message #290140 is a reply to message #290108] |
Thu, 18 August 2005 20:04   |
> Sunil
I can't find anything like that for this project. I've seen that for an
RCP application, but this is just a simple class that has no user interface.
I should also mention though, that I can run the programs from within
Eclipse and they run fine. I have the sql connector jars in the
libraries of the project properties - Java Build Path. And those jars
are the exact same path as where I put the final jar that I create.
Re: ClassNotFoundException with new .jar - but old one works??? [message #290147 is a reply to message #290140] |
Thu, 18 August 2005 21:01   |
>>> data
>>> months ago
>>> code (absolutely no changes), create a new jar, and it bombs. I'm
>>> fairly new to Java and Eclipse, so I'm not sure where to start.
>>> back to 3.0 and create a simple test program, it has the same problem.
>> driver jars are in the plugin classpath.
>> Sunil
> interface.
Is the jar file that contains the dbdriver classes on the runtime
classpath. Check in your Launch Config (Run->Run... menu)
Re: ClassNotFoundException with new .jar - but old one works??? [message #290273 is a reply to message #290147] |
Mon, 22 August 2005 12:23   |
>>>> data
>>>> months ago
>>>> I created several months ago, and it runs fine. I then take the
>>>> same code (absolutely no changes), create a new jar, and it bombs.
>>>> I'm fairly new to Java and Eclipse, so I'm not sure where to start.
>>> Sunil
>> an RCP application, but this is just a simple class that has no user
>> interface.
Yes, they are there.
Re: ClassNotFoundException with new .jar - but old one works??? (Got it figured out) [message #290485 is a reply to message #290147] |
Thu, 25 August 2005 13:14  |
>>>> data
>>>> months ago
>>> Sunil
>> interface.
As it turns out, I didn't know (or remember) to manually edit the
manifest file and put the Class-Path line in there. I don't remember
having to do that before, but being new to Java, and not having done it
for a while, I don't remember for sure.
Current Time: Wed Jul 16 02:02:45 EDT 2025
Powered by FUDForum. Page generated in 0.06504 seconds
