Home » Eclipse Projects » Eclipse Platform » Exception with 1.4.2_05 and not with 1.5
Exception with 1.4.2_05 and not with 1.5 [message #289970] Tue, 16 August 2005 03:48 Go to next message
Originally posted by: vducloux.cosmosbay-vectis.com
Hi everybody, my eclipse plugin uses "xmlbean" to write into an xml file
in the workspace.
The problem is that I get the following exception with j2sdk1.4.02_05
and not with jre1.5.0_02 !!!!
And a search on gooogle gave no results.. anyone can help me please ?
org.eclipse.core.runtime.CoreException[-1]:
org.xml.sax.SAXNotRecognizedException: Property:
http://java.sun.com/xml/jaxp/properties/schemaLanguage
org.apache.crimson.parser.XMLReaderImpl.setProperty(XMLReade rImpl.java:272)
org.apache.crimson.jaxp.SAXParserImpl.setProperty(SAXParserI mpl.java:190)
fr.cosmosbay.mrs.selenium.generators.TestCaseGenerator.isVal ideVdf(TestCaseGenerator.java:226)
fr.cosmosbay.mrs.selenium.generators.TestCaseGenerator.gener ateFrom(TestCaseGenerator.java:93)
fr.cosmosbay.mrs.selenium.resources.MyBuildDeltaVisitor.visi t(MyBuildDeltaVisitor.java:135)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:68)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:77)
org.eclipse.core.internal.events.ResourceDelta.accept(Resour ceDelta.java:49)
fr.cosmosbay.mrs.selenium.builders.seleniumBuilder.increment alBuild(seleniumBuilder.java:94)
fr.cosmosbay.mrs.selenium.builders.seleniumBuilder.build(sel eniumBuilder.java:62)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:570)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:159)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:251)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:204)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:231)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:234)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:270)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:299)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:155)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:212)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Re: Exception with 1.4.2_05 and not with 1.5 [message #289971 is a reply to message #289970] Tue, 16 August 2005 04:23 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
In Java 1.4 the 'built-in' xml parser is Crimson (in 1.5 it has been changed
to Xerces). From the exception I think that you use an xml schema for xml
validation and the Crimson parser does not support schemas.
You can either bundle a Xerces parser with your plugin and use that one for
processing xmls or use a dtd for validation purposes (I prefer the first
one). I do not know xmlbeans so I cannot give more specific advice.
HTH,
Csaba
> in the workspace.
> at
> at
> at
Re: Exception with 1.4.2_05 and not with 1.5 [message #289973 is a reply to message #289971] Tue, 16 August 2005 06:04 Go to previous messageGo to next message
Thanks, that's what I was thinking too...
I'll do the way you say, that means adding the jar, but in case one day
the plugin runs in a 1.5 environment won't there be a conflict between
the default xerces parser and the xerces parser I provide which can also
be of a different version ?
Horváth, Csaba wrote:
> HTH,
> Csaba
>>in the workspace.
>>at
>>at
>>at
Re: Exception with 1.4.2_05 and not with 1.5 [message #289977 is a reply to message #289973] Tue, 16 August 2005 08:53 Go to previous message
I don't use jdk 1.5 so I don't know that the two xerces conflict or not. On
page http://java.sun.com/j2se/1.4.2/docs/guide/standards/ sun specifies a
mechanism to provide newer version of an "endorsed standard library". I have
not tried it but - because sun wrote that 'officially' - it should work
(either specify the directory of xerces jar in the appropriate system
property or create the <java-home>/lib/endorsed directory and place the
xerces jar in it).
HTH,
Csaba
> Horv
Previous Topic:Creating MultiPageEditorPart inside a Text Editor
Next Topic:A question about Tree and TreeColumns
Current Time: Fri Nov 21 20:26:50 EST 2025
Powered by FUDForum. Page generated in 0.04376 seconds
