Home » Eclipse Projects » DTP » 50 records returned
50 records returned [message #28934] Wed, 04 April 2007 15:33 Go to next message
Originally posted by: irbull.cs.uvic.ca
This is probably pretty easy, but I can't find a way to change the
number of records returned when I click on a table and selected
Data->Edit. I am getting 50 records (there are 88 in the table). If I
create an SQL query select * from mytable, I get all 88.
cheers,
ian
Re: 50 records returned [message #29010 is a reply to message #28934] Fri, 06 April 2007 18:37 Go to previous messageGo to next message
This is a defect. The preference page from WTP was not ported to DTP and
so the Sample Contents feature always defaults to 50. I am not sure if we
need a new preference or it should just honor the the existing preference
for the SQL Results view. Feel free to open a defect for this.
Re: 50 records returned [message #33806 is a reply to message #29010] Wed, 01 August 2007 17:01 Go to previous message
has this been solved? I'm also not able to find the settings to increase
from 50 records.
If no issue yet has filled I would like to open a bug for this.
Best regards, Lars
"Larry Dunnell" <ledunnel@us.ibm.com> wrote in message
news:42042bb0d87534bd12d795428a3c330f$1@www.eclipse.org...
Re: 50 records returned [message #585095 is a reply to message #28934] Fri, 06 April 2007 18:37 Go to previous message
Re: 50 records returned [message #586954 is a reply to message #29010] Wed, 01 August 2007 17:01 Go to previous message
from 50 records.
Best regards, Lars
Previous Topic:Problems editing functions with Postgres
Next Topic:cannot create view (DB2) -- correct SQL statement does not work
Current Time: Mon Jul 14 00:38:04 EDT 2025
Powered by FUDForum. Page generated in 0.03028 seconds
