| Java Execution Problem [message #289089] |
Thu, 28 July 2005 15:29 |
Originally posted by: jai.kejriwal.air2web.com
I have a network messaging application that I was stress testing. The stress
testing code is part of a Java project within Eclipse. I was using Eclipse
to
launch the application and after making some design modifications(to the
messaging app source) the same tests yielded increased latency timings.
I thought that my design changes has caused this behavior. However, after
a few hours I tried to use the TPTP plugin to profile the application. When
I launched the same program through the TPTP plugin, the tests showed
the timings that I expected originally. I was very surprised by this
behavior.
I then tried lauching it through the normal way within Eclipse and once
again
the tests were slower. I then launched the program from the command line
and it ran faster.
This has left me really confused. Is there any possible explanation for this
behavior?
FUDForum. Page generated in 0.03049 seconds
