Home » Eclipse Projects » Eclipse Platform » @version tag auto-filled with revision number
@version tag auto-filled with revision number [message #287086] Thu, 23 June 2005 16:23 Go to next message
Originally posted by: bradley.wagner.hannonhill.com
Is there a way using Eclipse and CVS to autofill the @version Javadoc tag with the CVS revision
number of the file? Sun's documentation on @version tag mentions this sort of autmation:
http://java.sun.com/j2se/javadoc/writingdoccomments/index.ht ml#@version
Bradley
Re: @version tag auto-filled with revision number [message #287114 is a reply to message #287086] Fri, 24 June 2005 03:02 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
Because java source files are plain text files you can use all CVS-related
keywords.
In Preferences > Team > CVS page set 'Default keyword substitution' to
'ASCII with keyword expansion (-kkv)'.
After this setting you can use all $xx$ CVS keywords. For revision numbers
you can use '@version $Revision: $
You can use all CVS keywords:
http://www.badgertronics.com/writings/cvs/keywords.html
HTH,
Csaba
> with the CVS revision number of the file? Sun's documentation on @version
> Bradley
Re: @version tag auto-filled with revision number [message #287136 is a reply to message #287114] Fri, 24 June 2005 10:57 Go to previous messageGo to next message
Thanks, that's exactly what I was looking for. Do you know if there's anyway to make the time print
out as local time as opposed to GMT. I noticed that while if I view the Resource Historoy in Eclispe
it displays the local time, the CVS info is always in GMT.
Horváth, Csaba wrote:
> keywords.
> HTH,
> Csaba
>>Thanks,
>>Bradley
Re: @version tag auto-filled with revision number [message #287153 is a reply to message #287114] Fri, 24 June 2005 16:18 Go to previous messageGo to next message
> keywords.
And you can then wirte your own Javadoc version tag so that it gets
formated right in the html output.
Re: @version tag auto-filled with revision number [message #287156 is a reply to message #287153] Fri, 24 June 2005 16:41 Go to previous messageGo to next message
How?
>>keywords.
Re: @version tag auto-filled with revision number [message #287177 is a reply to message #287156] Sat, 25 June 2005 06:26 Go to previous message
http://java.sun.com/j2se/1.4.2/docs/tooldocs/javadoc/overvie w.html
and use ant and not the command line
> How?
>>> CVS-related
>>> keywords.
>>> numbers
Previous Topic:Why I can't see the icon on the button
Next Topic:Changing Project Type
Current Time: Fri Nov 07 17:12:48 EST 2025
Powered by FUDForum. Page generated in 0.04637 seconds
