Home » Eclipse Projects » Eclipse Platform » 3.1rc2 update site problem
3.1rc2 update site problem [message #286906] Tue, 21 June 2005 11:39 Go to next message
I'm trying to create an update site that will be used internally by
developers on my team so that we can all have the option of easily using a
standard set of plugins. I have created an update site using the new Update
Site project wizard. I selected the three plugins I wanted, built them all,
and published the site to my computer's apache server web directory. When I
try to access the site from my eclipse, it tells me, "No features found on
the selected site(s). Choose a different site or site category"
When I open an older version of Eclipse and point it at the site, it finds
the features fine. Every update site I visit now (presumably these sites
were made with a pre-3.1 version of Eclipse) works fine.
Re: 3.1rc2 update site problem [message #286914 is a reply to message #286906] Tue, 21 June 2005 13:28 Go to previous messageGo to next message
Originally posted by: chaves-do-not-spam.inf.ufsc.br
I just tried with 3.1 RC3 and a local update site and it worked fine.
If you have a test case people can use to reproduce the problem, please
open a PR against Platform/Update.
Rafael
Re: 3.1rc2 update site problem [message #286916 is a reply to message #286914] Tue, 21 June 2005 13:37 Go to previous messageGo to next message
Dumb question: what's a PR?
"Rafael Chaves" <chaves-do-not-spam@inf.ufsc.br> wrote in message
news:d7b7696e8e834daa1642c2dedc2b097e$1@www.eclipse.org...
> Rafael
Re: 3.1rc2 update site problem [message #286918 is a reply to message #286916] Tue, 21 June 2005 13:36 Go to previous messageGo to next message
"Chris" <cnorris@widen.com> wrote in message
news:d99j85$ri9$1@news.eclipse.org...
Eclipse committers jargon for problem report, meaning a bug submission in
Eclipse's bugzilla
Re: 3.1rc2 update site problem [message #286920 is a reply to message #286918] Tue, 21 June 2005 14:19 Go to previous messageGo to next message
I see. I will look into that.
In the meantime, I put the update site up on my webpage, so if investigation
of it would help, have at it:
http://neenersprinkledoodle.com/code/plugins/
"Philippe Ombredanne" <pombredanne@nexb.com> wrote in message
news:d99jak$rmu$1@news.eclipse.org...
> Eclipse's bugzilla
Re: 3.1rc2 update site problem [message #286921 is a reply to message #286920] Tue, 21 June 2005 14:32 Go to previous messageGo to next message
I tried with RC3 and it works fine. I didn't allow the plug-ins to
actually run (I removed them from my configuration after they were
installed). But they were installed properly.
Rafael
Re: 3.1rc2 update site problem [message #286923 is a reply to message #286921] Tue, 21 June 2005 14:44 Go to previous messageGo to next message
You're getting farther than I did. I will try rc3 now and see if it yields
any different results. This is odd that you can get things from that site
and I cannot. Maybe it's because I already have the plugins installed? If
that's the case, the message "no features were found" should perhaps be made
more informative.
news:2439f1399a92138d8bdcffd3f50b856f$1@www.eclipse.org...
>I tried with RC3 and it works fine. I didn't allow the plug-ins to actually
>run (I removed them from my configuration after they were installed). But
> Rafael
Re: 3.1rc2 update site problem [message #286925 is a reply to message #286923] Tue, 21 June 2005 15:04 Go to previous messageGo to next message
Yes, this is it.
> If
> more informative.
Please open a problem report if you want that to happen.
Rafael
Re: 3.1rc2 update site problem [message #286927 is a reply to message #286925] Tue, 21 June 2005 15:20 Go to previous messageGo to next message
I will do that.
When a plugin developer makes an update site, what is the standard way to
verify that the update site is functioning properly?
-Chris
news:bd4950b74bcc86a5a18f00f89f94bc00$1@www.eclipse.org...
> Yes, this is it.
>> If that's the case, the message "no features were found" should perhaps
>> be made more informative.
> Rafael
Re: 3.1rc2 update site problem [message #286928 is a reply to message #286927] Tue, 21 June 2005 15:22 Go to previous messageGo to next message
news:d99pa1$3om$1@news.eclipse.org...
> I will do that.
> -Chris
Chris, it works nicely on a 31rc3 from your update site.
There is really no standard way, but the way I do it is to have a vanilla
eclipse on hand, first start with a local update site, then move to test
with a remote site, and always starting with a vanilla eclipse & new
workspace.
Re: 3.1rc2 update site problem [message #286931 is a reply to message #286928] Tue, 21 June 2005 16:17 Go to previous message
I see. I did that with a fresh rc3 install and it worked just great.
news:d99phe$40s$1@news.eclipse.org...
>> I will do that.
>> -Chris
> workspace.
Previous Topic:Can't Launch or Start Eclipse after migration from 3.0.1 to 3.0.2
Next Topic:SWT_AWT Linux-GTK crash ?
Current Time: Wed Nov 12 22:40:11 EST 2025
Powered by FUDForum. Page generated in 0.04579 seconds
