Home » Eclipse Projects » Eclipse Platform » What is an "Invalid Stack Frame" error?
What is an "Invalid Stack Frame" error? [message #286354] Tue, 07 June 2005 12:37 Go to next message
I am getting an Invalid Stack Frame error.
What causes this?
According to the stack trace there is no connection to
my code.
Re: What is an "Invalid Stack Frame" error? [message #286355 is a reply to message #286354] Tue, 07 June 2005 12:52 Go to previous messageGo to next message
Usually this is a result of a failed hot code replace.
Most likely the target VM rejected the new byte codes as it did not support
hot code replace for some of the changes that had been made.
HTH
Darins
"Andrew Soloninka" <sandrew@us.ibm.com> wrote in message
news:t1jba1ph1i9v1470irooq4e5nn0ih25640@4ax.com...
> What causes this?
> my code.
Re: What is an "Invalid Stack Frame" error? [message #286414 is a reply to message #286354] Wed, 08 June 2005 17:13 Go to previous message
You also see this if you attempt an operation on a stack frame who's thread
has since resumed - like when the variables view tries to display variables
for a stack frame that no longer exists.
Darin
> What causes this?
> my code.
Previous Topic:Embed an editor into a view???
Next Topic:Eclipse Debugger Notifications
Current Time: Wed Nov 12 23:43:50 EST 2025
Powered by FUDForum. Page generated in 0.11362 seconds
