Home » Eclipse Projects » Eclipse Platform » Kill queued jobs in UI thread
Kill queued jobs in UI thread [message #285757] Wed, 25 May 2005 05:21 Go to next message
Originally posted by: niall.murphy.ie.ibm.com
sorry if i misuse the word job in this post, im using it to describe a
runnable queued on a thread that has yet to be run.
When i make a plugin wizard the class that creates the wizard,
NewProjectCreationOperation, also opens the manifest editor for the
created plugin.xml.
I dont want the editor to open.
at the moment i am closing the editor by adding the following runnable
to the UI thread. This happens before the next UI refresh. This means
there is (at best) a strange sight, as the editor opens, starts to draw
itself and then closes.
PDEPlugin.getActiveWorkbenchWindow().getShell().getDisplay() .asyncExec(new
runnable(){
public void run() {
IFile file = //is acquired
//get the editor associated with this file
IEditorPart ed =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().findEditor(new
FileEditorInput(file));
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().closeEditor(ed,
false);
What i would like to do is some how get the list of jobs of the UI
thread, pick the one that is going to open the editor and kill it before
the next ui refresh.
is this possible?
is there a better way?
thanks
Niall Murphy
Re: Kill queued jobs in UI thread [message #285769 is a reply to message #285757] Wed, 25 May 2005 10:21 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
There is no way to remove runnables from the asynchronous event queue.
Also, NewProjectCreationOperation is not an API class so referencing it
at all (let alone relying on its behaviour) is not recommended. I don't
have a suggestion for a better way to do this, other than writing your
own plugin wizard from scratch. You could enter a feature request
against PDE to make their wizard pages API, as is done by JDT and the
basic platform wizards (org.eclipse.jdt.ui.wizards and
org.eclipse.ui.wizards).
Niall Murphy wrote:
> created plugin.xml.
> runnable(){
> public void run() {
> IEditorPart ed =
> false);
> is this possible?
> thanks
> Niall Murphy
Re: Kill queued jobs in UI thread [message #285771 is a reply to message #285769] Wed, 25 May 2005 10:57 Go to previous message
Thanks for clarifying that John.
Niall
> Niall Murphy wrote:
>> created plugin.xml.
>> draw itself and then closes.
>> runnable(){
>> public void run() {
>> IEditorPart ed =
>> false);
>> before the next ui refresh.
>> is this possible?
>> thanks
>> Niall Murphy
Previous Topic:addListener to every Editor, not just active Editor
Next Topic:Ant Home
Current Time: Sun Aug 31 23:33:09 EDT 2025
Powered by FUDForum. Page generated in 0.23904 seconds
