Home » Eclipse Projects » Eclipse Platform » Eclipse/EPIC performance on FC3
Eclipse/EPIC performance on FC3 [message #285638] Fri, 20 May 2005 15:05 Go to next message
Originally posted by: lswick.spikesource.com
I'm running Eclipse on FC 3 2.6.11-1.14_FC3; it has 1gb of mem with a 60gb
h/d. The environment runs sluggishly, consuming 800mb or so of memory.
The min/max memory values have been set to various threshholds 256-640,
256-912, 128-640 etc...which does speed up the start up sequence. The IDE
though still coughs a lot.
Performance is even worse (no page refresh, gray screen) when I use the
EPIC plugin.
Anyone experience this? Any suggestions?
Lorinda
Re: Eclipse/EPIC performance on FC3 [message #285639 is a reply to message #285638] Fri, 20 May 2005 15:16 Go to previous messageGo to next message
Which Eclipse are you using?
Have you tried 3.1 M7?
Darins
"Lorinda" <lswick@spikesource.com> wrote in message
news:66670ae8d717955301fd4c846586e555$1@www.eclipse.org...
> EPIC plugin.
> Lorinda
Re: Eclipse/EPIC performance on FC3 [message #285644 is a reply to message #285639] Fri, 20 May 2005 15:59 Go to previous messageGo to next message
I'm using 3.0.2:
*** Features:
org.eclipse.jdt (3.0.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.2) "Eclipse Java Development Tools SDK"
org.eclipse.pde (3.0.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.2) "Eclipse Platform"
org.eclipse.platform.source (3.0.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.2) "Eclipse Project SDK"
org.epic.feature.main (0.3.0) "Perl Editor Plug-in"
org.tigris.subversion.subclipse (0.9.30) "Subclipse"
org.tmatesoft.javasvn (0.8.8.1) ""
Let me check 3.1 availability for FC3.
Re: Eclipse/EPIC performance on FC3 [message #285646 is a reply to message #285644] Fri, 20 May 2005 16:57 Go to previous message
Nevermind. Installing JEdit to see if that's easier to deal with.
Thanks.
Previous Topic:How to create ICompilationUnit from source
Next Topic:property page for project
Current Time: Fri Nov 07 09:17:16 EST 2025
Powered by FUDForum. Page generated in 0.04446 seconds
