Home » Eclipse Projects » Eclipse Platform » in which cases will those build menu items be disabled?
in which cases will those build menu items be disabled? [message #285613] Fri, 20 May 2005 04:50 Go to next message
i use wizard to create a plugin project. but i find i can't build it.(i
have deleted the META-INF folder,i want to write those info in
plugin.xml), those build menu items are disabled. i found in many cases
those menu items are disabled even if i currently select the proejct node
, why?
Re: in which cases will those build menu items be disabled? [message #285614 is a reply to message #285613] Fri, 20 May 2005 04:59 Go to previous message
sorry, i found the problem,because i have checked the auto build menu item
Previous Topic:Context menu missing standard group 'org.eclipse.ui.IWorkbenchActionConstants.MB_ADDITIONS'.
Next Topic:loading plugin at runtime
Current Time: Sun Aug 31 10:29:40 EDT 2025
Powered by FUDForum. Page generated in 0.03599 seconds
