Home » Eclipse Projects » Eclipse Platform » JSP plugin ?
JSP plugin ? [message #284700] Thu, 28 April 2005 17:35 Go to next message
Originally posted by: ale.mito.despammed.it
which free JSP plugin for Eclipse do you recommend ? I need an editor
(syntax color) most of all and it should be good having also a syntax error
check and code completion.
thanx
Ale
Re: JSP plugin ? [message #284713 is a reply to message #284700] Fri, 29 April 2005 01:00 Go to previous messageGo to next message
Originally posted by: antoni.alatalo.kolumbus.fi
load Eclipse 3.1 and Webtools. There is an jsp-editors and debugging
Ale wrote:
> thanx
> Ale
Re: JSP plugin ? [message #284765 is a reply to message #284713] Fri, 29 April 2005 21:22 Go to previous messageGo to next message
And after 50-150MB of downloads, you'll have a JSP editor. ;-}
You might want to try NitroX at http://m7.com. Only 42MB and still free.
Bob Foster
Antoni wrote:
> Ale wrote:
>> error check and code completion.
>> thanx
>> Ale
Re: JSP plugin ? [message #288226 is a reply to message #284713] Wed, 13 July 2005 17:00 Go to previous messageGo to next message
Originally posted by: dice.nospaminwind.it
On Fri, 29 Apr 2005 07:00:15 +0200, Antoni <antoni.alatalo@kolumbus.fi>
wrote:
> Ale wrote:
Same problem, already load
wtp-1.0M5.zip
JEM-SDK-I20050623.zip
GEF-SDK-3.1RC4.zip
emf-sdo-xsd-SDK-I200506230200.zip
need I something else?
(Sorry for my spaghetti english)
Re: JSP plugin ? [message #288262 is a reply to message #288226] Thu, 14 July 2005 10:50 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
> wrote:
>> Ale wrote:
>>> Hi,
>>> editor (syntax color) most of all and it should be good having also
>>> a syntax error check and code completion.
> wtp-1.0M5.zip
> GEF-SDK-3.1RC4.zip
WTP has a JSP editor (and debugger, I think).
What is the problem?
Re: JSP plugin ? [message #288264 is a reply to message #288262] Thu, 14 July 2005 11:44 Go to previous messageGo to next message
On Thu, 14 Jul 2005 16:50:17 +0200, Eric Rizzo <eclipse3@rizzoweb.com>
>> wtp-1.0M5.zip
>> GEF-SDK-3.1RC4.zip
No highlight, no runner, no debbuger, no wizard.
Re: JSP plugin ? [message #288333 is a reply to message #288264] Fri, 15 July 2005 12:06 Go to previous message
>>> wtp-1.0M5.zip
>>> GEF-SDK-3.1RC4.zip
I don't know what you are talking about, but the JSP capabilities of WTP
1.0M2 include all of those things. See here:
http://www.eclipse.org/webtools/wst/components/sse/M2/m2.htm l
HTH,
Eric
Previous Topic:linked resource trouble
Next Topic:How to avoid non release updates ?
Current Time: Sun Aug 10 14:38:19 EDT 2025
Powered by FUDForum. Page generated in 0.10392 seconds
