| Eclipse Jobs framework 3.0.2 [message #283470] |
Sun, 03 April 2005 15:46 |
I have been creating a plugin within Eclipse working entirely on version
3.0.1.
One of my requirements is that I need to find out when a java program has
completely finished executing in the console either by natural termination
or user termination by clicking the red terminate button. I successfully
did this in version 3.0.1 by adding an IJobChangeListener to the
platform's job manager:
final IJobManager jobManager = Platform.getJobManager();
then adding a IJobChangeListener to this implementing the done() method
only by using the JobChangeAdapter class, which has the signature:
public void done(IJobChangeEvent event) {...
I then monitor all the jobs that have been "done" and I found that the job
that is lastly done when a java program is terminated either naturally or
by user interaction is the job with the name "Process monitor". (I found
this out by examining the "Progress" view when executing a java program).
I find this out by:
if (event.getJob().getName().equals("Process monitor")) {...
I have now upgraded to eclipse 3.0.2 and it appears that the jobs
framework has changed where this job is no longer processed and
consequently I have no way of knowing when a java program has terminated,
which is the critical part of my plugin. I thought at first that the Job
name had changed, but in fact no jobs are done to notify a java program
has finished executing in 3.0.2. Hence my plugin no longer works. I can't
find any documentation at all either relating to this apparent change.
My question is then, is there any reason why this was removed from the
latest eclipse version and is there any other possible way of finding out
when a java program has finished executing?
Many Thanks,
Simon.
FUDForum. Page generated in 0.05943 seconds
