Home » Eclipse Projects » Eclipse Platform » unknown editor ID when launching an editor programatically
unknown editor ID when launching an editor programatically [message #283139] Mon, 28 March 2005 02:55 Go to next message
Originally posted by: Angel.Roman.prismtech.com
Hi All,
I'm using eclipse 3.0.1 and I'm trying to open an editor from within an
editor using the IWorkBenchPage.openEditor() method. However, I am
obtaining a PartInitException who's contents are:
Unable to open editor, unknown editor ID: com.foo.MySecondEditor
In other words I am doing the following:
page.openEditor(in, "com.foo.MySecondEditor");
where page is the active page.
I verified that the plug-in for my editor is installed correctly by
consulting the Plug-in Details on the About Eclipse dialog box. The
dialog box displays the id of my plugin as com.foo.MySecondEditor.
In addition, when a file is double clicked with the extension that is
associated with MySecondEditor, the editor is launched and I'm able to
use it.
Thanks in advance,
Angel Roman
Re: unknown editor ID when launching an editor programatically [message #283148 is a reply to message #283139] Mon, 28 March 2005 09:58 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
The name you are passing into openEditor does not match what you put in
your plugin.xml file.
Angel Roman wrote:
> Hi All,
> use it.
> Thanks in advance,
> Angel Roman
Re: unknown editor ID when launching an editor programatically [message #283151 is a reply to message #283148] Mon, 28 March 2005 10:33 Go to previous messageGo to next message
> Angel Roman wrote:
>> Hi All,
>> an editor using the IWorkBenchPage.openEditor() method. However, I am
>> use it.
>> Thanks in advance,
>> Angel Roman
Thanks for the response. However, the id specified in the plugin.xml
file matches the id that I am passing to openEditor(). Any other
clues/ideas would be appreciated.
Angel
Re: unknown editor ID when launching an editor programatically [message #283154 is a reply to message #283151] Mon, 28 March 2005 10:55 Go to previous messageGo to next message
>> in your plugin.xml file.
>> Angel Roman wrote:
>>> Hi All,
>>> to use it.
>>> Thanks in advance,
>>> Angel Roman
> Angel
Gilbert,
Thanks for your reply. You were 100% correct. I confused the ID for the
plugin with the ID for my editor.
Angel
Re: unknown editor ID when launching an editor programatically [message #283159 is a reply to message #283154] Mon, 28 March 2005 14:20 Go to previous message
>>> Angel Roman wrote:
>>>> Hi All,
>>>> am obtaining a PartInitException who's contents are:
>>>> is associated with MySecondEditor, the editor is launched and I'm
>>>> able to use it.
>>>> Thanks in advance,
>>>> Angel Roman
>> Thanks,
>> Angel
> Gilbert,
> Angel
glad to see you got it fixed up.
CL
Previous Topic:[Help]: HTTP 500 internal server error
Next Topic:decorate extension with TableViewer
Current Time: Wed Nov 05 02:44:17 EST 2025
Powered by FUDForum. Page generated in 0.46317 seconds
