Home » Archived » DSDP - Mobile Tools for Java (MTJ) » No javaME project
No javaME project [message #28221] Sat, 28 March 2009 08:02 Go to next message
I just installed MJT version 1.0 stable.
Problem:
-In Windows/Preferences JavaME doesn't appear
-In New/Project I don't have the option for JavaME
I have eclipse Version: 3.3.2 Build id: M20080221-1800
I installed MJT version 1.0 stable.
I modified the config.ini file.
In the plugin list I have:
-org.eclipse.mtj.branding 0.9.0.v200903210230
-org.eclipse.mtj.core.hooks 0.9.0.v200903210230
-org.eclipse.mtj.docs.isv 1.0.0.v200903210230
-org.eclipse.mtj.doc.user 0.9.0.v200903210230
-org.eclipse.mtj.example.so 1.0.0.v200903210230
-org.eclipse.mtj.source 1.0.0.v200903210230
Anna
Re: No javaME project [message #28262 is a reply to message #28221] Mon, 30 March 2009 07:03 Go to previous message
Hi Anna,
MTJ 1.0 only support Eclipse SDK 3.4.x or 3.5.x because we require some
features that were only made available in the 3.4 version.
If you require using the eclipse version 3.3.2 I suggest that you try to
use MTJ 0.9.1 but if not, you could upgrade your eclipse installation to a
3.4.x version or higher and try out the new MTJ 1.0M6 version :)
Diego
Re: No javaME project [message #572165 is a reply to message #28221] Mon, 30 March 2009 07:03 Go to previous message
Hi Anna,
Diego
Previous Topic:No javaME project
Next Topic:MTJ Webinar - April 22th
Current Time: Fri Jun 06 21:18:41 EDT 2025
Powered by FUDForum. Page generated in 0.03112 seconds
