Home » Eclipse Projects » Eclipse Platform » Problems with update sites
Problems with update sites [message #282840] Tue, 22 March 2005 00:56 Go to next message
Originally posted by: andrew.jackman.thalesatm.com
I'm currently using Eclipse 3.0.
When trying to use the standalone update feature (because we have no net
access directly) to create an update site, I'm finding that some sites are
failing and emptying my site.xml file. Obviously then the entire site is
useless.
Has anyone else seen this before?
E'.
Re: Problems with update sites [message #282841 is a reply to message #282840] Tue, 22 March 2005 01:00 Go to previous message
> useless.
> E'.
Ooops. this might help.
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 Mar 22, 2005 16:44:46.65
!MESSAGE Exception launching the Eclipse Platform:
!STACK
org.eclipse.update.internal.mirror.MirrorSite.writeDescripti on(MirrorSite.ja
va:567)
org.eclipse.update.internal.mirror.MirrorSite.writeCategorie s(MirrorSite.jav
a:554)
org.eclipse.update.internal.mirror.MirrorSite.writeSite(Mirr orSite.java:500)
at org.eclipse.update.internal.mirror.MirrorSite.save(MirrorSit e.java:482)
at org.eclipse.update.internal.mirror.MirrorSite.save(MirrorSit e.java:462)
org.eclipse.update.internal.mirror.MirrorSite.mirrorAndExpos e(MirrorSite.jav
a:65)
org.eclipse.update.internal.mirror.MirrorCommand.run(MirrorC ommand.java:74)
org.eclipse.update.internal.standalone.StandaloneUpdateAppli cation.run(Stand
aloneUpdateApplication.java:29)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
!SESSION Mar 22, 2005
16:46:15.924 ---------------------------------------------
java.version=1.4.1_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Command-line arguments: -command mirror -from
http://eclipsecorba.sourceforge.net/update -to F:\EclipseUpdateSite\updates
!ENTRY org.eclipse.update.core 4 0 Mar 22, 2005 16:46:15.934
!MESSAGE Error parsing site stream. [Document root element is missing.]
!STACK 0
org.xml.sax.SAXParseException: Document root element is missing.
at org.apache.crimson.parser.Parser2.fatal(Unknown Source)
at org.apache.crimson.parser.Parser2.parseInternal(Unknown Source)
at org.apache.crimson.parser.Parser2.parse(Unknown Source)
at org.apache.crimson.parser.XMLReaderImpl.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
org.eclipse.update.core.model.DefaultSiteParser.parse(Defaul tSiteParser.java
:118)
org.eclipse.update.core.model.SiteModelFactory.parseSite(Sit eModelFactory.ja
va:73)
org.eclipse.update.internal.mirror.MirrorSiteFactory.createS ite(MirrorSiteFa
ctory.java:68)
org.eclipse.update.internal.mirror.MirrorCommand.getMirrorSi te(MirrorCommand
..java:124)
org.eclipse.update.internal.mirror.MirrorCommand.run(MirrorC ommand.java:56)
java:226)
!ENTRY org.eclipse.core.launcher 4 0 Mar 22, 2005 16:48:50.747
!STACK
va:567)
a:554)
a:65)
java:226)
Previous Topic:AntCorePlugin Classloader
Next Topic:which plugin contributes "Last Edit Location" tool item to the main toolbar?
Current Time: Sun Aug 31 12:31:32 EDT 2025
Powered by FUDForum. Page generated in 0.50917 seconds
