Home » Eclipse Projects » Eclipse Platform » Running a process in background
Running a process in background [message #281240] Thu, 17 February 2005 03:46 Go to next message
Originally posted by: bozu.hotmail.com
i would like to run a process (a saving report process)in background. I
have a viewer like the adobe acrobat and i wan to run the saving process
in background while i continue to view my pdf file. How do you do that?
And how does display.asyncExec() method works? i try to test it but it is
not running in the background. In fact, it is running in the current
thread. I want it in a separate thread. Please advice.
thanks,
bozu
Re: Running a process in background [message #281253 is a reply to message #281240] Thu, 17 February 2005 09:28 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Look up Jobs. That will do what you want.
See:
http://eclipse.org/articles/Article-Concurrency/jobs-api.htm l
Rich Kulp
Re: Running a process in background [message #281265 is a reply to message #281240] Thu, 17 February 2005 12:09 Go to previous message
Originally posted by: Chris_Laffra.ca.ibm.com
Display.asyncExec runs in the main thread. This may be the "current" thread,
but it may not be.
You need asyncExec if you run outside the UI thread and need to access the
UI somehow.
For an explanation of asyncExec see:
http://www.eclipsefaq.org/chris/faq/html/faq140.html
As Rich Kulp says, Jobs are your friend for background activities:
http://www.eclipsefaq.org/chris/faq/html/faq127.html
If you really want to run another physical OS process, see
org.eclipse.swt.program.Program.launch(String)
Chris Laffra, http://eclipsefaq.org
"bozu" <bozu@hotmail.com> wrote in message
news:cv1lkm$3ki$1@www.eclipse.org...
> Hi
> thanks,
> bozu
Previous Topic:Use variable environment in debug mode for Junit
Next Topic:Message Box
Current Time: Sun Nov 02 23:05:59 EST 2025
Powered by FUDForum. Page generated in 0.04345 seconds
