Tuple Type problems [message #27977] |
Thu, 14 June 2007 06:24  |
We tried to parse the Tuple types but for some cases the results were not as
it's expected. The example of OCL Input below results in the same Tuple Type
for both seqInTuple1 and seqInTuple2, which is the Tuple contained of
Sequence(Integer). When the order of the OCL input is changed, both of the
elements have the type of Tuple contained of Sequence(String). We are using
mdt-ocl-SDK-1.1M7. The parsing process is invoked using parse(OCL Input)
operation of org.eclipse.ocl.ecore.OCL.
package p
context CTupleTypes
def def9:
seqInTuple2 : Tuple(names:Sequence(Integer)) = OclInvalid
context CTupleTypes
def def8:
seqInTuple1 : Tuple(names:Sequence(String)) = OclInvalid
endpackage
Any help is appreciated.
Jibran
Re: Tuple Type problems [message #28017 is a reply to message #27977] |
Thu, 14 June 2007 10:08   |
Hi, Jibran,
That's a fairly severe bug, and the only way that you can work around it (I
think) is by using a different name for the "names" part of each of the
tuple types. e.g.,
Tuple(names:Sequence(String)) and Tuple(intNames:Sequence(Integer))
Please raise a bug and we'll see whether we can get this fixed in time for
the release. The tuple types should recognize the difference between
Sequence(Integer) and Sequence(String).
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MDT& component=OCL&version=1.1.0&severity=major
Christian
A. Jibran Shidqie wrote:
> as it's expected. The example of OCL Input below results in the same Tuple
> Type for both seqInTuple1 and seqInTuple2, which is the Tuple contained of
> using mdt-ocl-SDK-1.1M7. The parsing process is invoked using parse(OCL
> Input) operation of org.eclipse.ocl.ecore.OCL.
> package p
> context CTupleTypes
> def def9:
> context CTupleTypes
> def def8:
> endpackage
> Best regards,
> Jibran
Re: Tuple Type problems [message #28056 is a reply to message #28017] |
Fri, 15 June 2007 05:59  |
Hi Christian,
I've added to the Bugzilla, as in the link below:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192832
Jibran
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:f4ri5n$k3a$1@build.eclipse.org...
> Hi, Jibran,
> (I
> tuple types. e.g.,
> Cheers,
> Christian
>> Tuple
>> of
>> the
>> package p
>> context CTupleTypes
>> def def9:
>> context CTupleTypes
>> def def8:
>> endpackage
>> Best regards,
>> Jibran
FUDForum. Page generated in 0.03032 seconds
