| [how to] accept drags from Task View? [message #279982] |
Wed, 26 January 2005 11:38  |
WinXp; R2.1 and 3.0 (still pushing to get the team migrated ...)
Although when I read the code of the Task View and the FAQ's about IMarkers (e.g.,
http://www.eclipsefaq.org/chris/faq/html/faq288.html and references there) I find no reference to
drag-n-drop from the Task View, I found by accident that in 2.1 I can drag a Task into Notepad or
into Mozilla's newsgroup-email composer, and in general into any external app that accepts textual
drops. But that no longer works in 3.0 (although the drag-cursor says it is working, with the little
"plus sign").
It looks like this, from 2.1:
Kind Status Priority Description Resource In Folder Location
Warning The import java.io.IOException is never used XmlType.java
com.foo.bar/src/com/foo/bar/metadata/metamodel/types line 3
But what is the drag-type in Eclipse? I.e., if I wanted to make one of our views or editors accept
drops from the TaskView, what would I have to do? And can this be done in 3.0?
thanks,
Paul
| Re: [how to] accept drags from Task View? [message #280681 is a reply to message #280522] |
Mon, 07 February 2005 17:52   |
OK, thanks for the bug-reference.
But I am able to drop from TaskView in 2.1 into Notepad, so, in 2.1 -- what would I use to accept
the drop? I mean, what kind of Transfer or whatever would it be?
thanks,
Paul
John Arthorne wrote:
> This doesn't currently work due to a bug in the task view:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=69871
>> IMarkers (e.g., http://www.eclipsefaq.org/chris/faq/html/faq288.html
>> and references there) I find no reference to drag-n-drop from the Task
>> or into Mozilla's newsgroup-email composer, and in general into any
>> external app that accepts textual drops. But that no longer works in
>> "plus sign").
>> Location
>> XmlType.java com.foo.bar/src/com/foo/bar/metadata/metamodel/types
>> line 3
>> our views or editors accept drops from the TaskView, what would I have
>> thanks,
>> Paul
| Re: [how to] accept drags from Task View? [message #280734 is a reply to message #280681] |
Tue, 08 February 2005 13:44  |
Originally posted by: john.eclipsefaq.org
org.eclipse.ui.part.MarkerTransfer (org.eclipse.ui.ide plugin)
> what would I use to accept the drop? I mean, what kind of Transfer or
FUDForum. Page generated in 0.04085 seconds
