Home » Eclipse Projects » Eclipse Platform » extending my own extension point
extending my own extension point [message #279894] Tue, 25 January 2005 09:15 Go to next message
Originally posted by: 0kcc.qlink.queensu.ca
I have used the following references to learn how to create extension
points. Faq#85 from the online version of eclipsefaq.org
http://docs.codehaus.org/display/UDIG/Creating+and+Using+Ext ension+Points
http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. pde.doc.user/guide/pde_schema_editor.htm
I created an extension point in the plugin I am developing. Then I go to
Run run-time workbench.
In the run-time workbench I create a New Plugin Project. However when I
go to plugin.xml -> extensions page on the wizzard I cannot find the
extension point I previously created.
Also in the run-time workbench if I go to Help->About->Plugin Details, I
can see that my plugin (that I declared the extension in) is loaded.
Is there something else I must do to see the extension point I made?
Maybe somebody has a suggestion here, as there was no response from the
newcomer group.
Any help is appreciated. Thanks,
Kevin
Re: extending my own extension point [message #279900 is a reply to message #279894] Tue, 25 January 2005 10:11 Go to previous message
Originally posted by: kim_horne.ca.ibm.com
Kevin wrote:
I've replied to your question in the newcomer group.
> Hello,
> newcomer group.
> Kevin
Previous Topic:JTestCase && JUnit Plug-In Test not compatible?
Next Topic:In-memory projejct
Current Time: Sat Jul 26 10:02:51 EDT 2025
Powered by FUDForum. Page generated in 0.43212 seconds
