Home » Eclipse Projects » Eclipse Platform » Starting Orsgi Bundle
Starting Orsgi Bundle [message #278980] Tue, 11 January 2005 12:04 Go to next message
I created one OSGi bundle. I want to start that bundle automatically when
my bundle is installed.
I understand there is some StartLevel service which can be used. I can set
the StartLevel to 1.
I am not undrestanding where do I specify my initial startlevel so that if
I install my bundle it will automatically start.
Currently on installing my bundle it goes to Resolved state.
Is there some Header to be used to specify that my bundle should be
started automatically.
Any help appreciated.
Re: Starting Orsgi Bundle [message #279037 is a reply to message #278980] Tue, 11 January 2005 17:22 Go to previous messageGo to next message
Originally posted by: tom.musta.nospam.com
Eclipse-AutoStart: true
in your manifest?
"S Dix" <siddhi1972@yahoo.com> wrote in message
news:cs10ul$f2a$1@www.eclipse.org...
Re: Starting Orsgi Bundle [message #279125 is a reply to message #279037] Wed, 12 January 2005 09:34 Go to previous messageGo to next message
Yes the Eclipse-AutoStart: true is present in the manifest. My bundle goes
in the Resolved state. I have to start it explicitly. I want my bundle to
startup when the framework startsup.
> in your manifest?
Re: Starting Orsgi Bundle [message #279148 is a reply to message #279125] Wed, 12 January 2005 11:25 Go to previous messageGo to next message
Originally posted by: chaves.inf.no.ufsc.spam.br
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=50164
> goes in the Resolved state. I have to start it explicitly. I want my
> bundle to startup when the framework startsup.
>> in your manifest?
>>> when
>>> can set
>>> that if
Re: Starting Orsgi Bundle [message #296522 is a reply to message #279148] Fri, 23 December 2005 02:47 Go to previous messageGo to next message
Originally posted by: tom.knube.org
You have to put your bundleid into the osgi startup list of
the config.ini but make sure your dependend bundles are loaded
before since the auto-loading is done by the
org.eclipse.update.configurator.
osgi.bundles=yourbundle@1:start,org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
The Eclipse-AutoStart: true is starting the bundle as I know when
a class is loaded form the plugin but this is all eclipse specific
stuff. You can specifiy the real osgi startlevel in the config.ini.
or another possibility would be to extend the Istartup extension Point
from Eclipse. So your Plugin get loaded during the workbench startup.
Rafael Chaves schrieb:
> See:
>>> in your manifest?
>>>> when
>>>> can set
>>>> that if
Re: Starting Orsgi Bundle [message #296530 is a reply to message #296522] Fri, 23 December 2005 10:32 Go to previous message
--------------010806060504020606080304
>> See:
>>>> in your manifest?
>>>>> automatically when
>>>>> can set
>>>>> that if
HERE IS IT
Content-Type: image/png;
name="screen.png"
Content-Disposition: inline;
filename="screen.png"
iVBORw0KGgoAAAANSUhEUgAAAQIAAADCCAIAAAAtslsHAAAACXBIWXMAAA7E AAAOxAGVKw4b
AAAAB3RJTUUH1QwXDx8qm6QlbgAAAAd0RVh0QXV0aG9yAKmuzEgAAAAMdEVY dERlc2NyaXB0
aW9uABMJISMAAAAKdEVYdENvcHlyaWdodACsD8w6AAAADnRFWHRDcmVhdGlv biB0aW1lADX3
DwkAAAAJdEVYdFNvZnR3YXJlAF1w/zoAAAALdEVYdERpc2NsYWltZXIAt8C0 jwAAAAh0RVh0
V2FybmluZwDAG+aHAAAAB3RFWHRTb3VyY2UA9f+D6wAAAAh0RVh0Q29tbWVu dAD2zJa/AAAA
BnRFWHRUaXRsZQCo7tInAAABAElEQVR4nO3dPY7cNhTA8acgXc6Ryga8nY00 O3uRXCBdLjBS
mz5AkDqlC5fuVtM5nQM4VW6QPrVSyMvlih+iRImkqP8PxmJWliiKw0fq69nN Dz/+Jtv5/ee7
V2/e/v3Xn+Ovr9687brulz/+HX/9759f1Zrfff+TWjJ+VqwLrX+rF2hd6CnZ upqnhpMPnm09
pbn4W2ayx0l9rEcXvnBpO4itTfwVdi2c1M2zlXVfs9XzN4K+vEkZBnXwRyl0 R2mrb3NXwMkc
AuUIDepR3xFZuWbLkpUbBsU23+qKFXtE2zriYe4eBtfr9XrdeydAlN3DoOu6 vXcBREpxUsR0
kFfXdXwFfinCaI6bGgAAAQBJREFUQN04QkZ8Cx7f5K4AkF/SO0Wv796JyJfP n6y/Io2x2XV8
BRlumL6+e0e7ZxfyFZxnnOKkCMj0+Mw6IeiT9fi35vQtxjnVZCFWU2O/ee5a ffMWNBt8+fxp
/COOLq7/lfqqPAEDj9d378Y/s2tWHwOSZTYYxxvzC1jRlen9q5mdW/9eztD1 dXlOitTMq+it
H965z/ZtYScFnRStFji5w2/dSFSHbGEwGchV6wd+AZP1mRaWUtcGngY/T0gk PSmydn3Xr2Jc
HE/Woeuv42q3MzdyDSdFQCTCANj5pGhMNnj/4eOue8Essj78dr826Pt+710A kVJcIhMJKBzX
BgBhAJT8D0z23nAAAAEASURBVLSIyDAM44emaWLWAfySzwZtu3QLf/+m9yNe 2jAYY2B5JAC7
IgwALpEBwgCQEsKgbVvrTyCZHDdMVS9Xnb5tW+MzkEz+2SDQMAzqEYH+GYiX NAzGwf75j7Zw
djZomkY9ItA/A/H2/U+f3n/42Pf96lfreIqMNIp+mSKkZ9P7Ee8w1wbAfggD IO1J0eTSl/ui
KES6MGhbuV7VXc7u67I22f4Bp0Rh0LZyuVxutwd94eVyadveXFPZ6S7QWGxk mdyhqkm62eD+
/tG2UP+tu916kX6yzup+pnd3/fMmHbdpGh7hVSPxDVPvPxNyS1UL4KUC7hTd nn7ez6yoG56Y
SyaD9GQo7S0UAAABAElEQVQd0d7FGF6yFjV5g4MZoEoFhMH9UwwEzwbm2Y5a oi8c6adArtMh
T1GuPaImWcNAnweWzAaqO5qddUUfDX9Wbe4RdcgaBvcvY2DJtYF1YG4029bU tUfUIVMYmPPA
khgYR31Xv9zjDN6/Rxxd2jCw9v6wGNA7t+seqFpnslCWjOWTolx7RE3S3TD9 +uxMRcLk55xJ
5zP7orV3Wq+PzQ+uz65LbVQm3VNk87lYIHU2koZ5vRGyGg7t8PkGuXbK5FCT Ap4bALkRBgD5
BgD5BoCcM99glno+cJ4HBauPtI68i5rzDeId+qudtUkORh15F+QbACXcKQrO N5jNAXDlD3hK
cC3UE6frowAAAQBJREFU/8pT8qLSFtXBc2ieMuXlayCz9Ze5HIylR3dQBYRB 2JtFw1xGwWSF
wBI8xZpc24aXtrQO1kNzVXLRG+P+rSbvm6xoq2M5ZL5BDM9ItvQN7ci0h6W7 ix+DN7nUqW8q
kMwvU0TkG6y27VXveIE4vHzraacL60Ku1wupxrYOmW8QzzqkLR3n9ABYUdq6 YTV8q13H7Mrm
hMPkG1gzCjwrjPRf/TkJrmJ1rm39pcXXYbZY68qeA1m6pqcadThMvoEE5BiY eQKzWQr+Ylck
OYRXMnIrz2lY+MrmkXo+uCpfgXryDSajWq1fWGnqODWqJ99g135PULnU0TIF PDcAciMMAPIN
APVjlCIAAAEASURBVPINACHfwErdF9/8Bnl4gXusGShXs2dEvoHPefqBrqki hWAR8g2AEu4U
nSzfYOlWswe1qMx1Fa5eAWFwpnwDa51Dtpot01yhebJJhetGvsGzpQkAqutM NpwdWa172Xw8
Nsf41RWuHvkGsaWNfSj+/bNtK2YO/GovW1W4JuQbzCycLcR1OrFuiN11YN6j wnUg3yBpvsG6
Qwsp039ckx2tO/yKkW+QNN8g5HPIrkNOaZYe7JmRb4CpE54akW+Qv/DSdn3C EaSA5wZAboQB
QL4BQL4BIOQbWKmb6EXdTZ/USoqpWAXIN/Apqp/pTzNOeE9zV+QbACXcKTpZ vsGKcvQ6zLTN
ftpJAAABAElEQVQRVikgDM6Ub+Cvg6sc7I18g2fJ8g0Cy0Ey5BvEljZ2+sjX 963lIBnyDWYW
zhYS//q+vxwkQL5B0nwDfx1c5WBv5BskzTdYUQfXsWBD5BuUyH8sTBGbI98g f+FLd3foCC9T
Ac8NgNwIA4B8A4B8A0DIN7BSt/BDHiakrE/M5jElVI98A59D9JvZICE/YRb5 BkAJd4rOlG9g
1nZR4Z7yrY1gaUTYFBAGZ8o3WFG4+S5GeCMQCYHIN3iWK99gkZCRnqlgKfIN Yksb+1xkvkEg
c/5x1WqnCtSKfIOZhbOFrMs3SDBaMyeEI98gT75BeOHWCwDPVUH44UAh36CI fIPAokIWiOkg
kAAAAQBJREFU0vVXIN+gfpwazSLfoPLCE5RfgQKeGwC5pZgNmJRP4rjTTqLZ QH/22XWd9WeD
I0vTkXaSMt+gvV6vTdOMl7yun8nqAyipL5H1F2YmP2+37R+hqdvn3EeP4W+9 Ck56i75TFMl8
GoV1/K3XHP81vgxhoNrU8yYCkFKGMJi87BC+sh4/k4WeZ2fqwiNkZVhNzi2V akaxDM8Nwm8y
qNbXm9u6UC9cHMFjLRPrVBMAo5yzwe12G4ZL0/QhW4X0Wnp2GvW1c7bZYIyB y0WG4VJfs+JY
ss0Gfd9cLtI0MgzyaPk3K+xbETDYQ8Zrg77vZRik7+XhwbmmxGUIzJYJSN5r g6aRx23LHVEA
AAD2SURBVEd5eFicT2gu1Jeoz9aF+mciIZC/SSu4XM75+Ozpzk+GnSqcZUES h8Eer0ssRb+H
KVEYBM6Yh55YcVwpwoABGIUj+wwgDADCABDCABDCABDCABDCABDCABDCABDC ABDCABDCABDC
ABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDC ABDCABDCABDC
ABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABDCABiGgTAA mA0AwgAQwgAQ
wgAQwgAQwgAQwgAQwgAQwgAQwgAQwgAQwgBomoYwAOR/+rO6pZedw94AAAAA SUVORK5CYII=
--------------010806060504020606080304--
Previous Topic:Stale plugin.jar
Next Topic:Dock API for non-RCP apps
Current Time: Fri Nov 07 21:32:13 EST 2025
Powered by FUDForum. Page generated in 0.05547 seconds
