Home » Eclipse Projects » Eclipse Platform » New perspective and menu not avaible
New perspective and menu not avaible [message #278775] Thu, 06 January 2005 18:16 Go to next message
Hi, there,
After new installation, if I run eclipse once before I copy my plugin to the
plugin folder my perpective and global menu are not available. If I copy my
plugin right after new install then run eclipse then everything works fine.
The workaround is to delete "eclipse\configuration\org.eclipse.osgi" folder
and restart eclipse.
What's the right way fix it without manully deleting files?
Thanks!!!
Jim
Re: New perspective and menu not avaible [message #278776 is a reply to message #278775] Thu, 06 January 2005 18:38 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
Jim wrote:
> Hi, there,
> Thanks!!!
> Jim
Run eclipse with -clean should work.
Peter
Re: New perspective and menu not avaible [message #278810 is a reply to message #278776] Fri, 07 January 2005 10:54 Go to previous messageGo to next message
Peter,
Thanks for your reply. The question will be how can I enforce user to do
that in the production level. User may just assume it's not working if he
didn't use -clean option.
Thanks.
Jim
"Peter Manahan" <manahan@NOSPAM.ca.ibm.com> wrote in message
news:crki6m$500$1@www.eclipse.org...
> Jim wrote:
>> Hi, there,
>> the plugin folder my perpective and global menu are not available. If I
>> copy my plugin right after new install then run eclipse then everything
>> works fine.
>> folder and restart eclipse.
>> Thanks!!!
>> Jim
> Peter
Re: New perspective and menu not avaible [message #278884 is a reply to message #278810] Mon, 10 January 2005 05:14 Go to previous message
Jim,
At production level, it is probably better you get the users to use the
Update Manager for installing and updating plugins. You just wrap the
plugins into a feature and provide that. (See
http://eclipse.org/articles/Article-Update/keeping-up-to-dat e.html ) The
Update Manager makes the necessary configuration changes so that you don't
need -clean.
Ciao,
Leif
Previous Topic:MIDP Development- how to include jar files?
Next Topic:how to custom open and close project
Current Time: Sun Nov 23 01:19:12 EST 2025
Powered by FUDForum. Page generated in 0.03557 seconds
