Home » Eclipse Projects » Eclipse Platform » Creating jsp in eclipse
Creating jsp in eclipse [message #277940] Sun, 19 December 2004 14:43 Go to next message
Originally posted by: andreas_bauer.arcor.de
I want to create jsp and servlets with eclipse. Is the jsp-compiler in the
Webserver Tomcat or in J2EE? Do I need J2EE (1_4)? I have installed Java
5.0. Is the docu and the classes for JSP and Servlets in J2EE ? Can I use
Java 5.0 and J2EE together?
Many Thanks
Andreas
Re: Creating jsp in eclipse [message #277987 is a reply to message #277940] Mon, 20 December 2004 10:11 Go to previous message
Andreas wrote:
> Hello,
> Many Thanks
> Andreas
You indeed need J2EE (and Tomcat or another Servlet container to run the
JSPs and Servlets).
There's no problem using JDK 5.0 with J2EE, I'm doing it all the time and
so do many others I'm sure.
Mind that Eclipse has no syntax highlighting of JSP by default, you will
need to add a plugin for that (there's several, both free and commercial).
Previous Topic:Suppress warnings for a particular java file
Next Topic:Linked Files and Editors
Current Time: Sun Aug 31 18:27:12 EDT 2025
Powered by FUDForum. Page generated in 0.02461 seconds
