Home » Eclipse Projects » Eclipse Platform » Case Insensitive Syntax Highlighting
Case Insensitive Syntax Highlighting [message #277896] Sat, 18 December 2004 13:34 Go to next message
Originally posted by: anthony.whitford.com
I am writing a plug-in for a case-insensitive language (like SQL). The code
samples that I am working with don't really show how I can make a
case-insensitive word rule.
The code sample from JDG2E simply specifies each keyword in both upper and
lower case for the WordRule. This means that "SELECT" and "select" will be
highlighted, but "Select" and "SeLeCt" should also be a match because SQL is
a case insensitive language.
Can anyone point me in the right direction for the best way to add case
insensitive syntax highlighting?
Thanks!
Re: Case Insensitive Syntax Highlighting [message #277903 is a reply to message #277896] Sat, 18 December 2004 14:07 Go to previous messageGo to next message
Originally posted by: bert.visi.com
In news:cq1t88$odc$1@www.eclipse.org "Anthony Whitford"
Dunno about "best way", but I simply implemented my own
"CaseInsensitiveWordRule" that otherwise worked just like "WordRule".
Bert Hyman St. Paul, MN bert@visi.com
Re: Case Insensitive Syntax Highlighting [message #277907 is a reply to message #277896] Sat, 18 December 2004 16:45 Go to previous message
> Thanks!
I posted a solution on how to do this a few days ago. See my replies
under "[Syntax Highlighting] Colouring specific keywords??".
Rob Watkins
Previous Topic:deprecated
Next Topic:Example of integrating Proguard into the Plugin export process?
Current Time: Fri Nov 07 12:41:01 EST 2025
Powered by FUDForum. Page generated in 0.03231 seconds
