Home » Eclipse Projects » Eclipse Platform » 'javaeditor' example from CVS is broken?
'javaeditor' example from CVS is broken? [message #277767] Thu, 16 December 2004 11:41 Go to next message
Hello all,
I've spent the entire afternoon trying to recover the
'org.eclipse.ui.examples.javaeditor' project. I really need a working
example to get my head around eclipse's editors - and it's becoming almost a
(bad) joke how many ways the samples don't work as they're supposed to.
Using the web-frontend for CVS, I got to this page:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ui.exam ples.javaeditor/
Which seems to be very similar to the file structure I pulled off the
"Official Eclipse FAQ's" CD.
However, I went through the entire CVS folder and pulled down the latest
copies of all the files and put them into a folder within my default eclipse
workspace ( "C:\Program
Files\eclipse\workspace\org.eclipse.ui.examples.javaeditor" ).
I then loaded up Eclipse and imported a project (pointing at the .project
file in the above folder). All seemed well - the navigator in eclipse
mirrors the files that were on the file system. Had a few warnings and
errors in some of the files regarding the auto-indent strategies. Tweaked
those a bit to stop it complaining (I dont think this would be the cause of
my main problem though).
When I load up a runtime workbench to test out the editor plug-in it works,
but as soon as I "Open External File" on a .jav I get the following error:
"Problems occurred when invoking code from plug-in:
'org.eclipse.core.runtime'." reported in the runtime workbench. With the
following stack-trace:
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException:
org.eclipse.ui.examples.javaeditor.JavaEditor
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:404)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader
..java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.jav
a:336)
... snipped ...
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
And the following error is outputted by the original Eclipse instance in the
output window:
org.eclipse.ui.PartInitException: Unable to instantiate editor:
org.eclipse.ui.JavaEditor org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.ui.examples.javaeditor was unable to load class
org.eclipse.ui.examples.javaeditor.JavaEditor.
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:798)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:
775)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:585)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:573)
... snipped ...
From what I can see it's having a problem loading the resource bundles for
the plugin. But they appear to be in the project (
"JavaEditorMessages.properties" etc...).
I can hope that I'm doing something wrong, or got something configured
incorrectly - but I don't know what I'm looking for! Does anyone here have
any suggestions?
I seriously doubt that the files in CVS are broken, but given how little
I've done to alter anything I'm starting to think it's a possibility!
Any help is **greatly** appreciated!
Jack
Re: 'javaeditor' example from CVS is broken? [message #278456 is a reply to message #277767] Mon, 03 January 2005 05:15 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Jack Hoxley wrote:
>Hello all,
> at
>.java:404)
> at
> at
>.java:307)
> at
>a:336)
> ... snipped ...
>output window:
> at
> at
>775)
> at
>.java:585)
> at
> ... snipped ...
>any suggestions?
Maybe you mixed versions: you probably downloaded some version and now
mix it with the latest example code (CVS HEAD). The easiest to get the
example is to download the example bundle from the corresponding
download page: on the download page of each drop, e.g. 3.0.1, you can
also download the examples.
Or even easier:
1. start Eclipse 3.0 (or later)
2. Help > Welcome
3. click on Samples.
Dani
>Cheers,
>Jack
Re: 'javaeditor' example from CVS is broken? [message #278462 is a reply to message #278456] Mon, 03 January 2005 05:36 Go to previous message
Originally posted by: jerryisdaman.gmail.com
the javaeditor example checked out from CVS does not work straight away
under the eclipse 3.0x ..... go and download eclipse 3.1 4M ..... it
works fine for me .....
Daniel Megert wrote:
> Jack Hoxley wrote:
>>Hello all,
>>workspace ( "C:Program
>>Fileseclipseworkspaceorg.eclipse.ui.examples.javaeditor" ).
>> at
>>.java:404)
>> at
>> at
>>.java:307)
>> at
>>a:336)
>> ... snipped ...
>>output window:
>> at
>> at
>>775)
>> at
>>.java:585)
>> at
>> ... snipped ...
>>any suggestions?
> Or even easier:
> 2. Help > Welcome
> Dani
>>Cheers,
>>Jack
Previous Topic:Developing a custom text editor
Next Topic:drop to editor view
Current Time: Thu Oct 30 22:25:42 EDT 2025
Powered by FUDForum. Page generated in 0.04176 seconds
