Home » Eclipse Projects » Eclipse Platform » TableViewer displaysTable, but Table is shifted right.
TableViewer displaysTable, but Table is shifted right. [message #276989] Thu, 02 December 2004 13:17 Go to next message
I have created a View that contains a TableViewer, and the TableViewer
contains a Table I explicitly define for it. The View is created
programmatically when the user selects an action from a context menu using
IViewPart newView =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().showView(classID,
classID + "." + altViewID, IWorkbenchPage.VIEW_ACTIVATE);
// I'll explain this stuff below
TabularDataManager tableData = new TabularDataManager(query);
if(newView instanceof com.powertech.audit.views.TabularResultView)
((TabularResultView)newView).recreateWithData(tableData, altViewID);
Since I need to use the showView() method to get the view to display it
initially has no data and simply contains a blank dataset and an empty
Table. Once the new View is created I call a method on the view that sets
the data I want the view to display and then creates a new Table using the
data ( recreateWithData() ). The method then creates a new TableViewer,
passing it the new Table via the TableViewer constructor. The TableViewer
is then refreshed with the refresh() method. The table appears in the
View with all the columns and data displayed but the entire table is
shifted right about half the width of the View window. In other words if
the text drawing below is the entire View the Table begins as shown:
View
| Blank | Table |
| Space | Displays |
+ ----- Table begins here
I suspect that the blank space is due to the initial blank Table that
somehow isn't getting removed and the view is trying to display, but I
don't know how to remove the reference to the original blank Table. I
don't even know if this is what is causing the problem. I've posted my
createPartControl(), createTable(), and recreateWithData() methods from my
View below. Please, any help would be appreciated.
public void createPartControl(Composite parent)
System.out.println("Enter TabularResultView:createPartControl()");
// Save a copy of the parent of this view
viewParent = parent;
// Determine if data is already set to be loaded into a view
if(tabularDataManager != null)
if(tabularDataManager.hasData())
// Create the table
createTable();
// Create the viewer
viewer = new TableViewer(table);
else
// Create blank data and an empty table
tabularDataManager = new TabularDataManager();
table = new Table(viewParent,
SWT.H_SCROLL | SWT.V_SCROLL |
SWT.MULTI | SWT.FULL_SELECTION);
viewContentProvider = new ViewContentProvider();
viewLabelProvider = new ViewLabelProvider();
viewer.setContentProvider(viewContentProvider);
viewer.setLabelProvider(viewLabelProvider);
viewer.setInput(tabularDataManager);
System.out.println("Leave TabularResultView:createPartControl()");
private void createTable()
Vector columnHeadings = tabularDataManager.getColumnHeadings();
System.out.println("columnHeadings.size() = " + columnHeadings.size());
System.out.println("class of first element" +
columnHeadings.firstElement().getClass());
layout = new TableLayout();
table.setLayout(layout);
table.setLinesVisible(true);
table.setHeaderVisible(true);
for( int i = 0; i < columnHeadings.size(); i++ )
String columnHeading = (String)columnHeadings.elementAt(i);
layout.addColumnData(new ColumnWeightData(50,100,true));
TableColumn newColumn = new TableColumn(table, SWT.NONE);
newColumn.setText(columnHeading);
newColumn.setResizable(true);
public void recreateWithData(TabularDataManager newDataMgr, String tabName)
// Update the underlying data model
tabularDataManager = newDataMgr;
// Create a table using the new underlying data model
createTable();
setTabName(tabName);
// Assign the viewer an new TableViewer that uses the new table.
// Keep the old content and label providers but update the view's
// input.
viewer.refresh();
Why would the above code cause the Table to display shifted right? I know
I must be missing something simple. Again, any help would be greatly
appreciated.
Jason
Re: TableViewer displaysTable, but Table is shifted right. [message #277091 is a reply to message #276989] Fri, 03 December 2004 18:38 Go to previous message
Okay! I found out what I was doing wrong. My initial hunch that the
orginal, blank table was the culprit for the blank space was correct. To
solve the problem I simply placed a viewer.getTable().dispose(); before
recreating the viewer with the new populated table in my
recreateWithData() method. My new recreateWithData() method is posted
below:
createTable();
// Assign the viewer a new TableViewer that uses the new table.
// input.
viewer.getTable().dispose(); // <--- New Addition to Fix Problem!
viewer.refresh();
I hope this helps anyone who runs into a similar issue.
Jason
> IViewPart newView =
> View
> | Blank | Table |
> | Space | Displays |
> // Create the table
> createTable();
> else
> createTable();
> // input.
> viewer.refresh();
> appreciated.
> Jason
Previous Topic:ContentType for a file with no extension
Next Topic:Build - osgi.install.area not set.??
Current Time: Sun Aug 31 22:43:02 EDT 2025
Powered by FUDForum. Page generated in 0.35872 seconds
