Home » Eclipse Projects » Eclipse Platform » Failed to connect to CVS repository using ext-method with CVS_RSH=/usr/athena/bin/rsh
Failed to connect to CVS repository using ext-method with CVS_RSH=/usr/athena/bin/rsh [message #276862] Tue, 30 November 2004 10:27 Go to next message
Originally posted by: jojo.virtutech.se
I'm trying to connect to a CVS repository using the 'ext' method, using
/usr/athena/bin/rsh as the external program, but Eclipse fails to
connect, popping up a dialog box saying "Unknown response received from
cvs server:". No more info is given. On Eclipse's stdout/stderr, the
following is printed:
Valid-responses ok error M E Checked-in Valid-requests Template
Set-sticky MT Clear-static-directory Module-expansion
Set-static-directory Clear-sticky New-entry Merged Removed Updated
Remove-entry Update-existing Copy-file Created Notified Mod-time
valid-requests
I've tried searching in the newsgroups, but without much luck. The
webinterface to newsgroups would be *much* more usable if for example
Google could index it.
Anyway, I've found some pointers to bugzilla-entries
(http://bugs.eclipse.org/bugs/show_bug.cgi?id=11633,
http://bugs.eclipse.org/bugs/show_bug.cgi?id=21180), but I can't really
determine if they are relevant here, or if they provide a solution for me.
Another solution would be if Eclipse could support the 'kserver' method.
I'll stick to pcl-cvs in Emacs until I can get this working, but it
would be great to be able to use cvs from inside Eclipse.
Any help would be appreciated.
/Jesper
Re: Failed to connect to CVS repository using ext-method with CVS_RSH=/usr/athena/bin/rsh [message #276977 is a reply to message #276862] Thu, 02 December 2004 09:52 Go to previous messageGo to next message
Jesper,
I suspect that the rsh client you are using is inserting whitespace
characters that are not part of the CVS protocol. You may want to log a
bug since it should be possible to handle this.
By the way, most users configure their local CVS servers to support
pserver and connect to it that way. If your using Cygwin, this bug
explains how you can setup a local connection
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=6892).
Michael
> valid-requests
> /Jesper
Re: Failed to connect to CVS repository using ext-method with CVS_RSH=/usr/athena/bin/rsh [message #277044 is a reply to message #276977] Fri, 03 December 2004 08:57 Go to previous message
Michael Valenta wrote:
> Jesper,
Ok, thanks.
Using a pserver-based server is not an option, for security reasons.
/Jesper
Previous Topic:final parameters in generated methods
Next Topic:How to couple editor and views?
Current Time: Tue Jul 15 00:20:35 EDT 2025
Powered by FUDForum. Page generated in 0.19876 seconds
