Home » Eclipse Projects » Eclipse Platform » How to monitor changes in files and code ?
How to monitor changes in files and code ? [message #275800] Fri, 12 November 2004 11:01
Originally posted by: ottohelge.hotmail.com
I'm trying to develop a plug-in that notifies distributed developers about
changes and states of selected java files and code. In this regard I want to
notify "subscribers" about events, i.e. when selected files are opened,
deleted and changed (hopefully also what changes have been made). I also
want to implement a possibility to notify changes and deletion on parts of
the code like classes, methods and variables, based on the structure in the
outline. I'm planning to develop a plug-in aimed at users working trough
Eclipse and CVS, but if it's possible get the information needed from CVS
trough Eclipse.
Currently I'm using IResourceChangeListener to monitor changes to files
locally, but as far as I can see this only gives me the possibility to
monitor post-change, pre- and post-auto build of files. Are there other
events raised by Eclipse that I can use to monitor file changes? Which, if
any, events can I use to monitor source code changes or is there another
solution? Which possibilities do I have in Eclipse to monitor changes in
CVS?
Any code, reference suggestion or comment is appreciated!
Thanks in advance,
Otto
Previous Topic:3.1/3.0.1 crash with Suse 9.2 and KDE
Next Topic:problem with update() in tableviewer
Current Time: Wed Oct 29 20:03:38 EDT 2025
Powered by FUDForum. Page generated in 0.37537 seconds
