Home » Eclipse Projects » Eclipse Platform » How do I find a view programmatically in Eclipse 3.x.x?
How do I find a view programmatically in Eclipse 3.x.x? [message #275683] Wed, 10 November 2004 20:53 Go to next message
Thanks for any tips...
Re: How do I find a view programmatically in Eclipse 3.x.x? [message #275684 is a reply to message #275683] Wed, 10 November 2004 21:00 Go to previous messageGo to next message
I think I found the answer...Would the below work?
I use the IWorkbenchPage.findView(String viewId) to get my view...I know
I can get the view id from my plugin.xml file, but is there a
programmatic way of getting the view id?
I would appreciate any snippet of code, e.g., get the IWorkbenchPage
object, etc.
Re: How do I find a view programmatically in Eclipse 3.x.x? [message #275730 is a reply to message #275684] Thu, 11 November 2004 12:34 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
See Chapter 9 at http://eclipsefaq.org.
In particular, http://www.eclipsefaq.org/chris/faq/html/faq167.html shows
the way to the workbench page...
Chris
"AL" <unbonnevie@yahoo.com> wrote in message
news:cmugtk$v60$1@eclipse.org...
> object, etc.
> Thanks
Re: How do I find a view programmatically in Eclipse 3.x.x? [message #275737 is a reply to message #275730] Thu, 11 November 2004 13:57 Go to previous messageGo to next message
Thanks, but the code in the FAQ only shows the view...I am looking to
get the view object itself, based on the given view id. Also, how the
workbench page is gotten? (It's "..." part also that I am looking to
find out.) Thanks very much.
Snippet of code from FAQ:
IWorkbenchPage page = ...;
String id = "org.eclipse.faq.examples.BooksView";
page.showView(id, "1", IWorkbenchPage.VIEW_VISIBLE);
page.showView(id, "2", IWorkbenchPage.VIEW_ACTIVATE);
> Chris
>>object, etc.
>>Thanks
Re: How do I find a view programmatically in Eclipse 3.x.x? [message #275738 is a reply to message #275737] Thu, 11 November 2004 14:32 Go to previous messageGo to next message
Oopss...I see what you (Chris) meant now...
Here is what I do...
MyView myView =
(MyView)MyViewPlugin.getInstance().getWorkbench().getActiveW orkbenchWindow().getActivePage().findView( "com.xyz..views.MyView");
By the getActiveWorkbenchWindow() returns null because there is no display.
I call the above from ANOTHER plugin that imports 'MyViewPlugin'.
Thanks.
Alex.
>> Chris
>>> object, etc.
>>> Thanks
Re: How do I find a view programmatically in Eclipse 3.x.x? [message #275744 is a reply to message #275738] Thu, 11 November 2004 16:05 Go to previous messageGo to next message
As stated in the javadoc for getActiveWorkbenchWindow will return null when
called from a non-ui thread.
You will likely need to investigate Display.syncExec and Display.asyncExec
to post into the UI thread
HTH
Darins
news:cn0eib$cu9$1@eclipse.org...
> MyView myView =
..getActivePage().findView("com.xyz..views.MyView");
display.
> Thanks.
> Alex.
shows
> >> Chris
know
> >>> object, etc.
> >>> Thanks
Re: How do I find a view programmatically in Eclipse 3.x.x? [message #275794 is a reply to message #275744] Fri, 12 November 2004 10:41 Go to previous message
I did not get that subtle detail :-)
If you are running your code from a Job (as you should), you could consider
using a UIJob:
See http://www.eclipsefaq.org/chris/faq/html/faq187.html
Chris
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:cn0k5k$o2h$1@eclipse.org...
when
> HTH
> Darins
> > MyView myView =
> display.
> > Thanks.
> > Alex.
> shows
> > >> Chris
> know
> > >>> object, etc.
> > >>> Thanks
Previous Topic:Relationship between View
Next Topic:3.1/3.0.1 crash with Suse 9.2 and KDE
Current Time: Sun Oct 26 06:58:03 EDT 2025
Powered by FUDForum. Page generated in 0.04334 seconds
