Home » Eclipse Projects » Eclipse Platform » Howto deploy to Tomcat in Eclipse
Howto deploy to Tomcat in Eclipse [message #275667] Wed, 10 November 2004 14:26 Go to next message
Originally posted by: harry.raceeend.demon.nl
Hallo,
I need help howto "integrate" tomcat (v 5.5.4) in Eclipse 3.01
I installed tomcat in /usr/local/tomcat as root, tomcat works.
Eclipse (v 3.01) also works also fine.
I have installed the sysdeo plugin. The menu and icons appear in the
toolbar.
Now I create a tomcat project and add 1 jsp file to it.
But I don't know how to deply this "web-application"
Do someone know which steps to take for the deployment ?
thanks in advance
Harry van Rijn
Re: Howto deploy to Tomcat in Eclipse [message #275672 is a reply to message #275667] Wed, 10 November 2004 15:32 Go to previous messageGo to next message
Hello Harry,
there is no special deployment. The sysdeo plugin allows you to debug
directly the classes in your workspace.
First you have to go to window > preferences > tomcat and set the tomcat
home dir and which tomcat version is used.
Right-Click on your Tomcat-Project and select "tomcat > add context", this
will add your project to the server.xml.
Now you can start tomcat using the left of the three tomcat buttons.
Sometimes you have to add the project to the window > prefernces > tomcat >
?? classes to include ??
Kinde regards,
feri
"Harry van Rijn" <harry@raceeend.demon.nl> schrieb im Newsbeitrag
news:cmtq10$o3a$1@eclipse.org...
> Hallo,
> toolbar.
> thanks in advance
> Harry van Rijn
Re: Howto deploy to Tomcat in Eclipse [message #275676 is a reply to message #275672] Wed, 10 November 2004 17:11 Go to previous messageGo to next message
Hallo Ferenc,
Thanks for the quick reply, I also have fiddled a liitle bit. It is
because this material is new to me, but before I used JBoss,which you
need to deploy to. I did what you propose, in fact you make part of you
working directory accessible to tomact by modifying ../conf/server.xml
Well here was my problem, I installed tomcat as root, so it was
impossible modifying server.xml because of the user rights. I have
changed the owner of the tomcat install to that of mine. Now I can
change the server.xml. I understand that this tric is for development only.
I am now trying to create a jsp with some tags (core foreach). But the
now I am searchin how to add the jstl.jar and standard,jar. I put them
in the MyContext/WEB-INF/lib (with import , from filesystem) but nient,
no resolving. The red dot stays like some desease!
Can you let your light shine upon this ???
Btw are you from Magyar ???
bye
van Rijn Harry
Ferenc Hechler wrote:
> Hello Harry,
> Kinde regards,
> feri
>>Hallo,
>>toolbar.
>>thanks in advance
>>Harry van Rijn
Re: Howto deploy to Tomcat in Eclipse [message #275678 is a reply to message #275676] Wed, 10 November 2004 18:11 Go to previous message
Ok I found it, you must import the required jar's in the ../WEB-INF/lib
directory. And .... also version matters for jstl.jar & standard.jar
because version 1.0 needs <%@ taglib uri="http://java.sun.com/jsp/core"
and version 1.1 needs . . . uri="http://java.sun.com/jsp/jstl/core"
bye
Harry
Harry van Rijn wrote:
> Hallo Ferenc,
> bye
> van Rijn Harry
>> Hello Harry,
>> tomcat home dir and which tomcat version is used.
>> this will add your project to the server.xml.
>> tomcat > ?? classes to include ??
>> Kinde regards,
>> feri
>>> Hallo,
>>> toolbar.
>>> thanks in advance
>>> Harry van Rijn
Previous Topic:Listen for Marker Deletion??
Next Topic:Missing ResourceBundle in my created plugin
Current Time: Sun Jul 13 07:41:17 EDT 2025
Powered by FUDForum. Page generated in 0.04530 seconds
